[blockMesh] blockMesh for bigger mesh
Like Tree4Likes
  • 2 Post By bigphil
  • 2 Post By eugene
Old   October 12, 2010, 11:42
Default blockMesh for bigger mesh
Gijsbert Wierink
gwierink is on a distinguished road
Dear all,
I am trying to generate a blockMesh with 6.75 million cells and have some trouble:
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Aborted
I read in these threads (DNS mesh and Trouble with blockMesh) that it should be possible, but I did not really find an answer. Up to 2 million cells blockMesh builds the mesh, but more cells won't work. I am using 64 bit machine with 8 GB of memory (actually a cluster node since I can forget about it on my desktop). Would anyone have any tips? Many thanks!
Regards, Gijs
gwierink is offline   Reply With Quote
Old   October 13, 2010, 08:36
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
Hi Gijs,
I cannot say anything about blockMesh, but I've observed a similar barrier with snappyHexMesh. By using a machine with 12GB of RAM, I was able to obtain a mesh consisting of approximately 3.3 Mio cells. Maybe there is no alternative as to use more memory? I'm glad if anybody has an other suggestion?
Jens
jhoepken is offline   Reply With Quote
Old   October 13, 2010, 12:48
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
You could split up your geometry into smaller parts and then mesh each part, then merge and stitch the part meshes together with the mergeMeshes and stitchMesh utilities.
This is not a very nice way of doing it, but if you can't figure anything else out then it might be an option.
Philip
solefire and mgg like this.
bigphil is offline   Reply With Quote
Old   October 14, 2010, 03:17
Gijsbert Wierink
Hi guys,
@Jens: That's a long time ago, how's life? Hope you're doing well! Hmm, it seems that brute force (or actually memory) is the only way ... I'll let you know if I find something out.
@Philip: Thanks for the suggestion, good idea. Would a renumberMesh be helpful after I merge and stitch?
Regards, Gijs
Old   October 14, 2010, 06:45
bigphil's Avatar
Philip Cardiff
Gijs,
I'm not very familiar with renumberMesh but it seems to give you a more efficient mesh, so yes it probably would be a good idea after merging and stitching.
I'll keep that in mind the next time I use merge and stitch!
Philip
Old   October 14, 2010, 07:39
Gijsbert Wierink
Hi Philip,
I used renumberMesh after converting Fluent meshes to OpenFOAM. After the conversion the cellID numbering is not the most efficient for use in OF. renumberMesh renumbers the cellIDs for more efficient calculation, it can speed up the calculation time actually. However, I heard it doesn't work with MRF meshes. Maybe there are some tricks for that ...
Regards, Gijs
Old   October 14, 2010, 08:33
bigphil's Avatar
Philip Cardiff
Originally Posted by gwierink View Post
Hi Philip,
Thanks Gijs,
I will keep it in mind when I convert meshes from Gambit.
Philip
Old   October 14, 2010, 10:44
Jens Höpken
<offtopic>
So renumberMesh can help to use Fluent meshes? Does this work for the export of ICEM grids in the Fluent format as well? I've hat a lot of trouble with that in the past.
@gijs: Life is great so far
</offtopic>
Old   October 14, 2010, 10:57
Gijsbert Wierink
Hi Jens,
Good to hear you are well .
I have seen this effect with Gambit meshes (the .msh extension), converted to OF. I suppose that other meshing tools also do not necessarily generate the mesh cellID order that is most optimal for OF to calculate with. Some codes work with "x-y-z", but OF "stacks" cells on a pile based on cellID. Of course, OF also uses "x-y-z", but perhaps in a slightly different way. I am not sure, but my guess is that renumberMesh may also be effective for meshes generated by other tools, e.g. ICEM.
Regards, Gijs
Old   October 15, 2010, 03:11
Jens Höpken
Thanks Gijs I'll give it a try, on the next ICEM mesh I need to use for the simulations.
Old   October 15, 2010, 10:26
Eugene de Villiers
eugene is on a distinguished road
One way to make bigger blockMeshes is to make a smallish blockMesh, decompose it and then use snappyHexMesh with volume refinement to refine it into a bigger mesh.
The memory requirements of snappy are large because it always stores 2 meshes (new and old) and each processor in a parallel run contains the entire set of surface meshes used to define the geometry. It could be better though.
mgg and Fahime like this.
eugene is offline   Reply With Quote
Old   October 26, 2010, 10:17
Gijsbert Wierink
Ah great, thanks Eugene, I will give it a try.
We do have a larger machine available, but it uses multiple cores on a single node. Does anyone know whether blockMesh is multithreaded so it could run with the full amount of memory on the node? Thanks in advance!
Regards, Gijs
Old   October 26, 2010, 16:04
Eugene de Villiers
blockMesh is single core only. Just about all multi-socket nodes these days have a shared memory architecture though, so each core can use all the memory on the node if required.
Old   October 27, 2010, 03:37
Gijsbert Wierink
Thanks, Eugene, I will have a try
Regards, Gijs
Old   November 28, 2010, 23:51
pkr
pkr is an unknown quantity at this point
I just started using OpenFoam for evaluating it for multi-core/many-core machines. I need to create a mesh with large number of cells (~2 million).
So I was looking at nonnewtonianIcofoam. I refined the mesh using refineMesh utility. The current mesh structure is as follows:
Mesh stats
internal points: 0
faces: 29042
internal faces: 14182
cells: 7200
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 7180
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 20
I would like to increase the number of cells and faces in this mesh to a large value. How can it be done using blockMesh? Please suggest the required changes. It will be great if I can get some kind of help. Thanks!!
pkr is offline   Reply With Quote
Old   July 8, 2014, 05:53
Julien
Djub is on a distinguished road
Hello everybody,
it makes a long time that you wrote into this subject. Today four years later, I have the same kind of problem. I would like a ~18 Mcells blockMesh. Do I need only to ask more memory on my cluster ? I am asking for 8000mb and it is still too few...
Any idea / suggestion / comment ?
Djub is offline   Reply With Quote
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 05:03
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[blockMesh] blockMesh to generate the mesh of a deep cavity eddykendo OpenFOAM Meshing & Mesh Conversion 4 July 5, 2015 16:54
