[Gmsh] No 3D Element found during gmshToFoam conversion |
June 19, 2018, 09:47 |
Bhargav lakhlani
Rep Power: 8 |
Hello Everyone,
I am trying to create a mesh of simple room with one inlet and one outlet in gmsh. I have created geometry using the OpenCASCADE kernel with following script ......... //+ SetFactory("OpenCASCADE"); Box(1) = {0, 0, 0, 10, 10, 10}; //+ Box(2) = {1, 1, 1, 0.1, 1, 1}; //+ Box(3) = {9, 9, 9, 0.1, 1, 1}; //+ Physical Surface("Inlete") = {8}; //+ Physical Surface("Outlete") = {13}; //+ Physical Surface("Wall") = {4, 1, 3, 2, 5, 6}; Transfinite Line "*"= 10 ; Transfinite Surface "*" = 10; Transfinite Volume "*"= 10; Recombine Surface "*"; .......... Even though a 3D mesh is generating in gmsh, when I try to convert into the OpenFOAM mesh using the gmshToFoam command, I am getting an error showing "No 3D elements found". I am a novice user of gmsh so please suggest me some solution for this. Regards, Bhargav |
June 21, 2018, 09:37 |
Deep
Rep Power: 8 |
I'm not an expert and not 100% sure as I never encountered it before. But you are not defining a "Physical Volume". That could be a reason.
3d elements, gmsh, openfoam |
[RapidCFD] Discussion thread on how to install and use RapidCFD | newoscar | OpenFOAM Community Contributions | 84 | September 2, 2022 01:04 |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
missing vtf3.h BPatch.h papi.h | linch | OpenFOAM Installation | 41 | July 24, 2012 14:45 |
