[blockMesh] Creating circle blockmesh
Like Tree1Likes
  • 1 Post By hjasak
Old   June 16, 2006, 07:24
Default Creating circle blockmesh
Hrvoje Jasak
You can make a much nicer mesh than that: put a square in the middle and 4 blocks around it. The quality of the mesh will be better, you won't get the worning + the code will run faster.
Hrv
Hrvoje Jasak
Old   June 16, 2006, 08:27
Default You didn't get me right - I me
Hrvoje Jasak
You didn't get me right - I meant a mesh like this:
You should be able to see 5 blocks. As for the discretisation, try using least square gradients and the rest should be OK.
Hrv
mali likes this.
Hrvoje Jasak
Old   October 13, 2014, 15:28
cesarjets is on a distinguished road
Hrv
how you calculate the arcs of the block? To my knowledge it's done by using sine and cosine? thanks,
cesarjets is offline   Reply With Quote
[blockMesh] Wierd behaviour of blockMesh creating axis in wedge rcastilla OpenFOAM Meshing & Mesh Conversion 1 December 4, 2018 06:24
[blockMesh] Segmentation Fault when creating block mesh topography (blockMesh) jbrydg01 OpenFOAM Meshing & Mesh Conversion 2 May 11, 2017 05:37
[Other] Having problems creating the correct half of a circle vroembroem OpenFOAM Meshing & Mesh Conversion 3 July 3, 2016 18:24
[blockMesh] Error while running blockMesh Harak OpenFOAM Meshing & Mesh Conversion 0 December 11, 2014 09:36
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
