[blockMesh] Struggling to stitch or merge these blocks
Like Tree1Likes
  • 1 Post By alexeym
Old   November 3, 2014, 19:51
Default Struggling to stitch or merge these blocks
James Guthrie
Jabo is on a distinguished road
Hi
So I'm trying to use blockMesh and create one cylinder on top of another fatter cylinder, resembling a tube going into a chamber. I'll be simulating spray going through the tube into the cylinder using sprayFoam.
Here's my blockMeshDict:
convertToMeters 0.001;
vertices
    (-5 0 0)
    (-5 0 0)
    (5 0 0)
    (5 0 0)
    (-5 100 0)
    (-5 100 0)
    (5 100 0)
    (5 100 0)
    (-2.5 100 0)
    (-2.5 100 0)
    (2.5 100 0)
    (2.5 100 0)
    (-2.5 109 0)
    (-2.5 109 0)
    (2.5 109 0)
    (2.5 109 0)
blocks
    hex (0 1 2 3 4 5 6 7) (20 20 80) simpleGrading (1 1 1)
    hex (8 9 10 11 12 13 14 15) (4 4 16) simpleGrading (1 1 1)
edges
    arc 0 3 (0 0 -5)
    arc 1 2 (0 0 5)
    arc 4 7 (0 100 -5)
    arc 5 6 (0 100 5)
    arc 8 11 (0 100 -2.5)
    arc 9 10 (0 100 2.5)
    arc 12 15 (0 109 -2.5)
    arc 13 14 (0 109 2.5)
patches
    wall walls
        (2 6 5 1)
        (0 4 7 3)
        (0 1 5 4)
        (4 5 6 7)
        (7 6 2 3)
        (3 2 1 0)
    wall inlet
        (10 14 13 9)
        (8 12 15 11)
        (8 9 13 12)
        (12 13 14 15)
        (15 14 10 11)
        (11 10 9 8)
mergePatchPairs
and checkMesh:
Mesh stats
    faces:            97184
    internal faces:   93024
    cells:            32256
    faces per cell:   5.89683
    boundary patches: 2
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     28928
    prisms:        3328
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 2
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
  <<Writing region 0 with 32000 cells to cellSet region0
  <<Writing region 1 with 256 cells to cellSet region1
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    walls               4000     3962     ok (closed singly connected)
    inlet               160      154      ok (closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.005 0 -0.005) (0.005 0.109 0.005)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-2.59514e-17 4.45753e-18 -1.07301e-16) OK.
    Max cell openness = 1.11667e-15 OK.
    Max aspect ratio = 406.119 OK.
    Minimum face area = 2.40746e-09. Maximum face area = 1.8861e-06.  Face area magnitudes OK.
    Min volume = 3.00932e-12. Max volume = 1.06093e-09.  Total volume = 7.98082e-06.  Cell volumes OK.
    Mesh non-orthogonality Max: 85.0024 average: 28.873
   *Number of severely non-orthogonal (> 70 degrees) faces: 5120.
    Non-orthogonality check OK.
  <<Writing 5120 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 1.04775 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
I'm doing something wrong as running 'stitchMesh walls inlet' or using mergePatchFaces gives:
--> FOAM FATAL ERROR:
Zero length edge detected. Probable projection error: slave patch probably does not project onto master. Please switch on enriched patch debug for more info
From function void enrichedPatch::calcCutFaces() const
in file slidingInterface/enrichedPatch/enrichedPatchCutFaces.C at line 263.
FOAM aborting
I don't know where I'm going wrong, please advise.
Thanks
Last edited by Jabo; November 3, 2014 at 19:52. Reason: Tidy up, remove commented out code
Jabo is offline   Reply With Quote
Old   November 7, 2014, 04:39
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
during stitching process vertexes of slave patch are projected onto master patch, after new edges and faces are created. Success of the operation depends on the quality of the mesh. Your blockMeshDict produces rather low-quality mesh (or should I say no-quality), so stitching operation fails.
I've attached archive of a case where stitchMesh operation finishes successfully. You'll need gmsh to generate initial mesh.
Jabo likes this.
alexeym is offline   Reply With Quote
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 03:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[blockMesh] How to merge blocks? Match, merge or stitch? gerritgroot OpenFOAM Meshing & Mesh Conversion 0 November 13, 2015 20:59
[ICEM] Two boxes connected by a cylinder, blocks merge where I don't want them to merge. Polarbear ANSYS Meshing & Geometry 4 April 30, 2014 15:21
