[blockMesh] 2:1 refined 2D blockMeshDict with mergePatchPairs? |
December 1, 2014, 23:52 |
Christian Butcher
Rep Power: 12 |
I can generate a mesh if I omit the 'mergePatchPairs' section, but in that case, 'checkMesh' informs me I have x-many regions that are not connected by any faces.
If I remove duplicate vertices, I get errors relating to 'inconsistent number of faces' when running blockMesh. When I add a 'mergePatchPairs' section, blockMesh fails. In this case, the error is given as Code:
--> FOAM FATAL ERROR: Face 16384 reduced to less than 3 points. Topological/cutting error A. Old face: 2(20622 23184) new face: 2(20622 23184) From function void slidingInterface::coupleInterface(polyTopoChange& ref) const in file slidingInterface/coupleSlidingInterface.C at line 1481. FOAM aborting My intention is to provide a 2:1 refined initial mesh so as to bypass difficulties with 2D AMR (since the region of interest is very simple - just the middle) Does anyone know what I'm doing wrong? (and if there is a solution more trivial than "Go back to coding a modified fvRefineHexMesh class"?) My blockMeshDict is as follows: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // vertices ( (0 0.0 0) (160.0 0.0 0) (160.0 11.0 0) (0 11.0 0) (0 0.0 10.0) (160.0 0.0 10.0) (160.0 11.0 10.0) (0 11.0 10.0) (0 11.0 0) (160.0 11.0 0) (160.0 11.5 0) (0 11.5 0) (0 11.0 10.0) (160.0 11.0 10.0) (160.0 11.5 10.0) (0 11.5 10.0) (0 11.5 0) (160.0 11.5 0) (160.0 11.625 0) (0 11.625 0) (0 11.5 10.0) (160.0 11.5 10.0) (160.0 11.625 10.0) (0 11.625 10.0) (0 11.625 0) (160.0 11.625 0) (160.0 16.0 0) (0 16.0 0) (0 11.625 10.0) (160.0 11.625 10.0) (160.0 16.0 10.0) (0 16.0 10.0) (0 16.0 0) (160.0 16.0 0) (160.0 24.0 0) (0 24.0 0) (0 16.0 10.0) (160.0 16.0 10.0) (160.0 24.0 10.0) (0 24.0 10.0) (0 24.0 0) (160.0 24.0 0) (160.0 28.375 0) (0 28.375 0) (0 24.0 10.0) (160.0 24.0 10.0) (160.0 28.375 10.0) (0 28.375 10.0) (0 28.375 0) (160.0 28.375 0) (160.0 28.5 0) (0 28.5 0) (0 28.375 10.0) (160.0 28.375 10.0) (160.0 28.5 10.0) (0 28.5 10.0) (0 28.5 0) (160.0 28.5 0) (160.0 29.0 0) (0 29.0 0) (0 28.5 10.0) (160.0 28.5 10.0) (160.0 29.0 10.0) (0 29.0 10.0) (0 29.0 0) (160.0 29.0 0) (160.0 40.0 0) (0 40.0 0) (0 29.0 10.0) (160.0 29.0 10.0) (160.0 40.0 10.0) (0 40.0 10.0) ); blocks ( hex (0 1 2 3 4 5 6 7) (320 22 1) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (640 2 1) simpleGrading (1 1 1) hex (16 17 18 19 20 21 22 23) (1280 1 1) simpleGrading (1 1 1) hex (24 25 26 27 28 29 30 31) (2560 70 1) simpleGrading (1 1 1) hex (32 33 34 35 36 37 38 39) (5120 256 1) simpleGrading (1 1 1) hex (40 41 42 43 44 45 46 47) (2560 70 1) simpleGrading (1 1 1) hex (48 49 50 51 52 53 54 55) (1280 1 1) simpleGrading (1 1 1) hex (56 57 58 59 60 61 62 63) (640 2 1) simpleGrading (1 1 1) hex (64 65 66 67 68 69 70 71) (320 22 1) simpleGrading (1 1 1) ); edges ( ); boundary ( side_left { type patch; faces ( (0 3 7 4) (8 11 15 12) (16 19 23 20) (24 27 31 28) (32 35 39 36) (40 43 47 44) (48 51 55 52) (56 59 63 60) (64 67 71 68) ); } side_right { type patch; faces ( (1 5 6 2) (9 13 14 10) (17 21 22 18) (25 29 30 26) (33 37 38 34) (41 45 46 42) (49 53 54 50) (57 61 62 58) (65 69 70 66) ); } bottom { type wall; faces ( (0 4 5 1) ); } top { type wall; faces ( (67 66 70 71) ); } frontAndBack { type empty; faces ( (1 0 3 2) (5 4 7 6) (9 8 11 10) (13 12 15 14) (17 16 19 18) (21 20 23 22) (25 24 27 26) (29 28 31 30) (33 32 35 34) (37 36 39 38) (41 40 43 42) (45 44 47 46) (49 48 51 50) (53 52 55 54) (57 56 59 58) (61 60 63 62) (65 64 67 66) (69 68 71 70) ); } pm0 { type ; faces ( (2 6 7 3) ); } ps0 { type ; faces ( (9 8 12 13) ); } pm1 { type ; faces ( (10 14 15 11) ); } ps1 { type ; faces ( (17 16 20 21) ); } pm2 { type ; faces ( (18 22 23 19) ); } ps2 { type ; faces ( (25 24 28 29) ); } pm3 { type ; faces ( (26 30 31 27) ); } ps3 { type ; faces ( (33 32 36 37) ); } pm4 { type ; faces ( (34 38 39 35) ); } ps4 { type ; faces ( (41 40 44 45) ); } pm5 { type ; faces ( (42 46 47 43) ); } ps5 { type ; faces ( (49 48 52 53) ); } pm6 { type ; faces ( (50 54 55 51) ); } ps6 { type ; faces ( (57 56 60 61) ); } pm7 { type ; faces ( (58 62 63 59) ); } ps7 { type ; faces ( (65 64 68 69) ); } ); mergePatchPairs ( ( pm0 ps0 ) ( pm1 ps1 ) ( pm2 ps2 ) ( pm3 ps3 ) ( pm4 ps4 ) ( pm5 ps5 ) ( pm6 ps6 ) ( pm7 ps7 ) ); // ******************************************************************************* // |
blockmesh, blockmeshdict, openfoam, openfoam-2.3 |
[blockMesh] mergePatchPairs problem when migrating from OFext1.6 to OFext3.1 | ma-tri-x | OpenFOAM Meshing & Mesh Conversion | 2 | January 12, 2021 04:23 |
[blockMesh] mergePatchPairs reducing a face to less than 3 points | aow | OpenFOAM Meshing & Mesh Conversion | 2 | June 1, 2018 17:37 |
2D AMR - matching faces that are not refined with refined faces | chrisb2244 | OpenFOAM Programming & Development | 9 | June 22, 2016 00:56 |
[blockMesh] BlockMeshDict with multiple hex blocks mergePatchPairs | prousa | OpenFOAM Meshing & Mesh Conversion | 1 | May 14, 2009 23:42 |
[blockMesh] MergePatchPairs in blockMeshDict | lord_kossity | OpenFOAM Meshing & Mesh Conversion | 0 | April 15, 2008 02:28 |
