[snappyHexMesh] Snappy in parallel mode
Like Tree9Likes
  • 1 Post By alexm
  • 8 Post By Tobi
Old   October 27, 2009, 13:50
Default Snappy in parallel mode
jajoju is on a distinguished road
Hi everybody
i am new to OpenFOAM and snappyHexMesh. I need to create a mesh with a lot of cells (arround 8 Mio.) so I thought it would be usefull to use more than one cpu. I tried to generate the mesh with the help of several cpu in OpenFOAM 1.6.x. Everything went fine so far after:
-blockMesh
-decomposePar
-mpirun -n 4 snappyHexMesh -parallel
-reconstructParMesh (after I added master time 1 to the controlDict)
If I open the mesh now in paraFoam I just can see the 'first mesh'. That means the surface is not smooth it's square cut (?).
Does anybody know if the step with the 'master time' was right (after that it finished reconstructing the first time!)? Maybe there is another mistake I made. I really hope that someone can help me! Thanks a lot!
Jakob
jajoju is offline   Reply With Quote
Old   October 27, 2009, 19:05
Axel Mohr
alexm is on a distinguished road
Hello Jakob,
I don't know what these 'master time' is you're about. Maybe there is another thing, I have to learn ;-)
After a parallel run of snappyHexMesh in each processor folder are the the folders for the 'time steps' 1 + 2 + 3 (if add layers had been set in snappyHexMeshDict).
For the smooth surface you need the second time step.
Normaly reconstructPar - without any parameter - will reconstruct each time step in the processor folders. You should try reconstructPar -time 2 (or '-time 3' or '-latestTime')
if you have problems, try this one:
reconstructParMesh -mergeTol 1e-03 -latestTime
Hope, that helps!
Good night and greetings, Axel
namsivag likes this.
alexm is offline   Reply With Quote
Old   October 28, 2009, 04:03
Hi Axel
thanks a lot it works!!! You really made my day!
best greetings Jakob
Old   December 3, 2014, 05:24
Eugen
estang is on a distinguished road
If i use reconstructPar without any parameters, it tells me that there is no times selected. If i run reconstructParMesh -mergeTol 1e-06 it tells me there is no mesh
Merge tolerance : 1e-06
Write tolerance : 1e-06
Doing geometric matching on correct procBoundaries only.
This assumes a correct decomposition.
Found 8 processor directories
Reading database "snappyMultiRegionLayerMeshing_2/processor0"
Reading database "snappyMultiRegionLayerMeshing_2/processor1"
Reading database "snappyMultiRegionLayerMeshing_2/processor2"
Reading database "snappyMultiRegionLayerMeshing_2/processor3"
Reading database "snappyMultiRegionLayerMeshing_2/processor4"
Reading database "snappyMultiRegionLayerMeshing_2/processor5"
Reading database "snappyMultiRegionLayerMeshing_2/processor6"
Reading database "snappyMultiRegionLayerMeshing_2/processor7"
Time = 0
No mesh.
End.
This is the tree of one processor after snappyHexMesh has run
├── processor7
│   ├── 0
│   │   ├── cellLevel
│   │   └── pointLevel
│   └── constant
│       └── polyMesh
│           ├── boundary
│           ├── boundaryProcAddressing
│           ├── cellLevel
│           ├── cellProcAddressing
│           ├── cellZones
│           ├── faceProcAddressing
│           ├── faces
│           ├── faceZones
│           ├── level0Edge
│           ├── neighbour
│           ├── owner
│           ├── pointLevel
│           ├── pointProcAddressing
│           ├── points
│           ├── pointZones
│           ├── refinementHistory
│           ├── sets
│           │   └── wrongFaces
│           └── surfaceIndex
whats wrong?
estang is offline   Reply With Quote
Old   December 3, 2014, 10:48
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
reconstructParMesh -mergeTol 1e-6 -constant
Why you have to use it because you are using
mpirun -np x snappyHeMesh -parallel -overwrite
Therefor -overwrite tells sHM to overwrite the mesh in constant/polyMesh and therefor you will not get a time folder. Hence this happens reconstructParMesh is not able to reconstruct a mesh because it is searching in a time folder which you do not have. To avoid this error you have to tell the application that you want to reconstruct the mesh in constant folder.
namsivag, Yage, maminow and 5 others like this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   December 4, 2014, 01:57
Thumbs up
Eugen
you solved my problem
Unsteady Inlet Velocity UDF in Parallel Batch Mode vtyler Fluent UDF and Scheme Programming 4 April 1, 2020 05:44
UDF Fluent running in Parallel mode Abhiroop FLUENT 2 September 1, 2016 17:19
problem with compiling boundary condition udf in parallel mode chem engineer Fluent UDF and Scheme Programming 11 June 29, 2015 06:23
Does anyone have any experience with cfd-fastran (2008.2) on parallel mode? CFD_1977 Main CFD Forum 0 March 30, 2014 07:01
How to run icoFsiFoam in parallel mode? AsDF OpenFOAM Running, Solving & CFD 2 February 21, 2014 07:56
