[mesh manipulation] Generating sets for cyclicAMI with setSet generates big error
Old   December 29, 2014, 13:33
Default Generating sets for cyclicAMI with setSet generates big error
Ferdinand Leinbach
effi is on a distinguished road
I am working on a Couette-Flow as described in my first thread, which i hope doesn't count as a duplicate post now .
I relink the picture for visualisation:
This time my questions is rather specific.
I was trying to utilise cyclicAMI-Boundarys on my Inlet and Outlet.
After setting up my inlet and outlet as described in this helpful answer in the boundary-file constant/polyMesh aswell in my 0/p and 0/U files (with the correction of & from the aforementioned guide to $ as in the tutorial cases for "value $internalField"),
was trying to run "setSet" and got this error message (click the files in the text to see the uploaded version to dropbox):
|  \\    /   O peration     | Version:  2.2.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.x-61b850bc107b
Exec   : setSet
Date   : Dec 29 2014
Time   : 19:12:28
Host   : "uc1n996"
PID    : 14339
Case   : /pfs/work2/workspace/scratch/st_lrt70667-test-0/cyclicAMI
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
--> FOAM FATAL ERROR:
Attempt to cast type patch to type cyclicAMI
    From function refCast<To>(From&)
    in file /opt/bwhpc/common/cae/openfoam/2.2.x/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude/typeInfo.H at line 114.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/bwhpc/common/cae/openfoam/2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/opt/bwhpc/common/cae/openfoam/2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::cyclicAMIPolyPatch const& Foam::refCast<Foam::cyclicAMIPolyPatch const, Foam::polyPatch const>(Foam::polyPatch const&) in "/opt/bwhpc/common/cae/openfoam/2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#3  Foam::cyclicAMIPolyPatch::neighbPatchID() const in "/opt/bwhpc/common/cae/openfoam/2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#4  Foam::cyclicAMIPolyPatch::calcGeometry(Foam::PstreamBuffers&) in "/opt/bwhpc/common/cae/openfoam/2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#5  Foam::polyBoundaryMesh::calcGeometry() in "/opt/bwhpc/common/cae/openfoam/2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  Foam::polyMesh::polyMesh(Foam::IOobject const&) in "/opt/bwhpc/common/cae/openfoam/2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
 in "/opt/bwhpc/common/cae/openfoam/2.2.x/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/setSet"
#8  __libc_start_main in "/lib64/libc.so.6"
Aborted
Can you tell me what I am doing wrong?
Thank you,
All the best,
Ferdinand
PS: The mesh was created using pointwise. You can finde the whole 0;constant;system Folders here.
effi is offline   Reply With Quote
Old   December 29, 2014, 14:55
Ferdinand Leinbach
Solved itself, found some errors in the Boundary File.
cyclicami, openfoam 2.2.x, setset
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
