[Gmsh] gmshToFoam: strange error
Like Tree2Likes
  • 1 Post By alexeym
  • 1 Post By alexeym
Old   January 20, 2015, 02:58
Default gmshToFoam: strange error
Samuele Z
samiam1000 is on a distinguished road
Dear Foamers,
could you help me with this: I do have a question about the utility gmsh. I have done a very simple geometry: one cylinder inside the other one and I have created a mesh with gmsh.
It seems to be a good mesh, but when I try to convert it using gmshTo Foam, I get this error:
szampini@archimede:~/Documenti/Afros/CFDSimulations/01dielectricCylinder$ mshToFoam meshGeneration.msh
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.1-262087cdf8db
Exec   : mshToFoam meshGeneration.msh
Date   : Jan 20 2015
Time   : 08:45:16
Host   : "archimede"
PID    : 25055
Case   : /home/szampini/Documenti/Afros/CFDSimulations/01dielectricCylinder
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM FATAL IO ERROR:
wrong token type - expected int, found on line 1 the word '$MeshFormat'
file: meshGeneration.msh at line 1.
    From function operator>>(Istream&, int&)
    in file primitives/ints/int/intIO.C at line 68.
FOAM exiting
Could you help?
Also, if I want to add patches name, could I do this with gmsh?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   January 20, 2015, 03:17
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
If you'd like to use gmshToFoam, use gmshToFoam, not mshToFoam as latter is Fluent mesh converter.
alexeym is offline   Reply With Quote
Old   January 20, 2015, 03:22
Samuele Z
Yeah,
that's what I did (I wrote it wrong in the post: I'm gonna to change it!).
Anyway, I solved this cleaning up everything and doing it again.
Also, as far as the patches are concerned, how can I give them a name?
Thanks a lot,
Samuele
Old   January 20, 2015, 03:30
Alexey Matveichev
In case of physical groups you can use strings instead of numbers, here's a fragment of the GEO file (if you start with GEO)
Physical Surface("bottom") = {14};
Physical Surface("top") = {16};
Physical Surface("sides") = {24, 18, 20, 22};
I don't know how to set string IDs in gmsh GUI, usually I edit file in external editor.
If you just have MSH file there's PhysicalNames section of the file, where you can set the names:
$PhysicalNames
4
2 1 "bottom"
2 2 "top"
2 3 "sides"
3 4 "cuboid"
$EndPhysicalNames
Second column is IDs of the physical groups.
Old   January 20, 2015, 04:17
Samuele Z
Great,
thanks a lot!
Samuele!
PS: could you check me .geo file, letting me know if it is "nice"?
Point(1) = {0,0,0};
Point(18) = {0,0.55,0};
Point(2) = {0.0125,0,0};
Point(3) = {0,0,0.0125};
Point(4) = {-0.0125,0,0};
Point(5) = {0,0,-0.0125};
Point(6) = {0.005,0,0};
Point(7) = {0,0,0.005};
Point(8) = {-0.005,0,0};
Point(9) = {0,0,-0.005};
Point(10) = {0.0125,0.55,0};
Point(11) = {0,0.55,0.0125};
Point(12) = {-0.0125,0.55,0};
Point(13) = {0,0.55,-0.0125};
Point(14) = {0.005,0.55,0};
Point(15) = {0,0.55,0.005};
Point(16) = {-0.005,0.55,0};
Point(17) = {0,0.55,-0.005};
Circle(1) = {2,1,3};
Circle(2) = {3,1,4};
Circle(3) = {4,1,5};
Circle(4) = {5,1,2};
Circle(5) = {6,1,7};
Circle(6) = {7,1,8};
Circle(7) = {8,1,9};
Circle(8) = {9,1,6};
Circle(9) = {10,18,11};
Circle(10) = {11,18,12};
Circle(11) = {12,18,13};
Circle(12) = {13,18,10};
Circle(13) = {14,18,15};
Circle(14) = {15,18,16};
Circle(15) = {16,18,17};
Circle(16) = {17,18,14};
Line Loop(1) = {1,2,3,4};
Line Loop(2) = {5,6,7,8};
Plane Surface(1) = {1,2};
Line Loop(3) = {9,10,11,12};
Line Loop(4) = {13,14,15,16};
Plane Surface(2) = {3,4};
Physical Surface("bottom") = {1};
Physical Surface("top") = {2};
Ruled Surface(3) = {1, 3};
Ruled Surface(4) = {2, 4};
Physical Surface("innerWall") = {3};
Physical Surface("outerWall") = {4};
With this code, do I get a cylinder inside the other one, with for patches: top, bottom, innerWall and outerWall?
Now, if the geometry is fine, how can I mesh it properly?
Old   January 20, 2015, 05:15
Alexey Matveichev
Well, you only describe two disks in your geometry. You have to connect them, define surfaces, then, using defined surfaces, define volumes. After you can add transfinite algorithm for mesh construction.
You can find compressed geo file in attachment. Also in attachment is a screenshot of the resulting mesh.
samiam1000 likes this.
Old   January 20, 2015, 05:23
Samuele Z
WoW: thanks a lot! Great mesh and very nice script. Thanks a lot!
Just 1 more questions: could you suggest me a pdf to learn GMSH?
Thanks a lot. Have a good day,
Samuele.
Old   January 20, 2015, 05:29
Alexey Matveichev
Reference manual is quite nice (http://www.geuz.org/gmsh/doc/texinfo/gmsh.html), sections 3-5 & 6.3.2 are of particular interest, it is available in PDF format (http://www.geuz.org/gmsh/doc/texinfo/gmsh.pdf) if you insist on PDF
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
