[snappyHexMesh] How to mesh a flow straightener
Old   February 1, 2015, 11:30
Exclamation How to mesh a flow straightener
Mohammad Fereshtehpour
MOHAMMAD67 is on a distinguished road
Send a message via Skype™ to MOHAMMAD67
Dear Foamers
Hi
I need to simulate flow in a flow straightener which is shown in the picture below. To do this I used snappyHexMesh but I couldn't achieve a good results. I don't know what the problem is? As It is shown the model geometry is wrong in the pipe near the internal pipes.
If you don't mind take a look at my case. I put it in the dropBox.
https://www.dropbox.com/s/evdrcrr7ot...owStr.zip?dl=0
Best Wishes
MOHAMMAD67 is offline   Reply With Quote
Old   February 1, 2015, 12:05
Default Some pictures
Here you can see both the geometry and meshed model.
Old   February 2, 2015, 13:04
Default My problem!
As you can see in the pictures, my problem is that the wall is not modelled correctly. The wall is not defined somewhere and in those places I have inlet patch as it is shown! Why?
I think there is a problem with snapping but I don't know How to deal with?
Old   February 2, 2015, 14:28
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Looks like you haven't refined it enough in the region where the tubes are: you may want to define a refinementRegion and increase to level so that you get at least 2 cells between then tubes and the wall.
mturcios777 is offline   Reply With Quote
Old   February 2, 2015, 15:02
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Exactly that is what I mentioned in your private message. It seems that you have no refinement at all.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   February 5, 2015, 01:03
Wink Problem Solved!
Dear Marco and Tobi
Thanks for your replies. Yes, you are right! I didn't set the snappyhexmeshDict to make mesh refinement. To solve this problem, I first increased maxGlobalCells to 300000 and it started to do this!.After that I tried to separate my geometry main pipe and tubes and apply them in refinementSurfaces and refinementRegions.
But now, I have more than 1000000 cells which makes my simulation very slow!! What should I do in this manner?
cylinder flow, snappyhexmesh
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
Influence of mesh density on laminar flow Ricevind FLUENT 2 June 16, 2014 08:53
mesh problem in flow region near thin structure... mytruth7 FLUENT 4 December 15, 2013 21:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
