[Commercial meshers] A problem of fluentMeshToFoam |
January 25, 2015, 00:02 |
Rep Power: 11 |
Good afternoon everyone:
Today I am using Gambit to creat meshes for an axi-symmetric model. The length of my model is 10m and radius is 2.3m.The geometry is specified as a wedge of 3 degrees.Just like the pictures attached. Around the axi and the pressure-in patch meshes are dense, other places are sparse.After converted gambit mesh to Foam mesh, I checked the meshes.But there is something wrong with one point.The following message came out: __________________________________________________ _____________ Checking geometry... Overall domain bounding box (0 0 -52.3539) (9000 1999.31 52.3539) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 1) Wedge wedge_back with angle 1.5 degrees ***Wedge patch wedge_back not planar. Point (0 1946.15 -50.9617) is not in patch plane by 9.37986e-08 metre. Boundary openness (-5.66076e-19 2.86545e-16 -2.65689e-15) OK. Max cell openness = 3.29734e-16 OK. Max aspect ratio = 55.5679 OK. Minimum face area = 0.147604. Maximum face area = 6906.99. Face area magnitudes OK. Min volume = 0.506237. Max volume = 138172. Total volume = 9.42047e+08. Cell volumes OK. Mesh non-orthogonality Max: 4.3741 average: 2.75779 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.33242 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. __________________________________________________ _____________ I've tried a lot of method such as to creat a smaller model(R 2m,L 9M), to creat mesh in other way...But all in vain. Is there anybody can help me? Thank you very much~ |
January 29, 2015, 20:32 |
Rep Power: 11 |
I've solved it by using the following order:
fluentMeshToFoam mymesh.mesh -scale 0.001 I forget to set the exchanging factor of millimeter to meter. |
Is COMSOL Multi Physics is suitable to solve complex flow problem? | steve lee | COMSOL | 8 | January 5, 2023 02:31 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 19:41 |
Mesh& steptime independant: conduction-convection problem | Fati1 | Main CFD Forum | 1 | October 28, 2018 13:52 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
