[blockMesh] Internal faces between blocks
Old   January 30, 2015, 14:56
Default Internal faces between blocks
Javier Cortabarra Sánchez
javierCS is on a distinguished road
Hi everybody,
Im working in a mesh that is supossed to be a beach with an "obstacle" at the bottom to study the breaking of the waves.
I got it in 2D, but now im getting a problem trying to make it 3D.
The problem is that some internal faces come out around the "obstacle". The solution, I think, is the face merging, but after reading the manual and making some tests... I am not sure I understood it correctly
Could somebody give me a lead about how to do it?
Thank you in advance
PS: Here is my bMD and an image of the resulting mesh attached
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
//cara 1
(0 -1 0) // 0
(0 1 0) // 1
(6 1 0) // 2
(15 1 0) // 3
(15 0 0) // 4
(6 -1 0) // 5
//cara 2
(0 -1 5) // 6
(0 1 5) // 7
(6 1 5) // 8
(15 1 5) // 9
(15 0 5) // 10
(6 -1 5) // 11
//cara 3
(0 -1 10) // 12
(0 1 10) // 13
(6 1 10) // 14
(15 1 10) // 15
(15 0 10) // 16
(6 -1 10) // 17
//cara 4
(0 -1 15) // 18
(0 1 15) // 19
(6 1 15) // 20
(15 1 15) // 21
(15 0 15) // 22
(6 -1 15) // 23
//plataforma
(10 -0.25 5) //24
(12.75 -0.25 5) //25
(10 -0.25 10) //26
(12.75 -0.25 10) //27
//auxiliares
(10 1 5) //28
(12.75 1 5) //29
(10 1 10) //30
(12.75 1 10) //31
blocks
hex (0 5 2 1 6 11 8 7) (10 10 10) simpleGrading (1 1 1)
hex (5 4 3 2 11 10 9 8) (10 10 10) simpleGrading (1 1 1)
hex (6 11 8 7 12 17 14 13) (10 10 10) simpleGrading (1 1 1)
hex (11 24 28 8 17 26 30 14) (10 10 10) simpleGrading (1 1 1)
hex (24 25 29 28 26 27 31 30) (10 10 10) simpleGrading (1 1 1)
hex (25 10 9 29 27 16 15 31) (10 10 10) simpleGrading (1 1 1)
hex (12 17 14 13 18 23 20 19) (10 10 10) simpleGrading (1 1 1)
hex (17 16 15 14 23 22 21 20) (10 10 10) simpleGrading (1 1 1)
edges
patches
patch inlet
((0 1 7 6)
(6 7 13 12)
(12 13 19 18))
patch outlet
((3 4 10 9)
(9 10 16 15)
(15 16 22 21))
wall bottom
((0 6 11 5)
(6 12 17 11)
(12 18 23 17)
(5 11 10 4)
(11 17 26 24)
(24 26 27 25)
(25 27 16 10)
(17 23 22 16))
patch atmosphere
((1 2 8 7)
(2 3 9 8)
(7 8 14 13)
(8 28 30 14)
(28 29 31 30)
(29 9 15 31)
(13 14 20 19)
(14 15 21 20))
mergePatchPairs
javierCS is offline   Reply With Quote
Old   February 3, 2015, 11:25
I solved it by adding more auxiliar blocks beside the obstacle, making the vertex coincide in order to get the "face matching".
Its not the more brilliant solution but its the one I got
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
