[snappyHexMesh] SHM does not snap my geometry |
June 19, 2017, 09:05 |
Twan Wilting
Rep Power: 8 |
Hello Foamers,
I am new to this Forum but I've been working with OpenFOAM for 3/4 weeks now. I did several tutorials before I start working on my own case but apparently there is something I'm still doing wrong and I can not find it. I would like to mesh a geometry using Snappy, the geometry doesn't need any layers. But even if it needed layers, something goes wrong in the snapping proces. The geometry itself is confidential, so I can not upload the .stl file. But a picture is added at the end of this Thread. (basically 2 'cylinders' on top of each-other). My snappyHexMeshDict and log file are given below, I really hope that anyone has an idea or some suggestions. ( In the shmDict addidtional stl files are listed but are not used for now. In the future I would like to add a bathymetry. ) Kind regards, Twan |
help needed, snap controls, snappy hex mesh, snappyhesmeshdict |
[snappyHexMesh] Failed Edge Snap with box geometry and correct feature capture | thiagomarinho | OpenFOAM Meshing & Mesh Conversion | 7 | May 7, 2022 09:19 |
[snappyHexMesh] problems with sHM: it doesn't snap! | Claudio87 | OpenFOAM Meshing & Mesh Conversion | 25 | July 10, 2020 08:06 |
[Workbench] Workbench 18.2 SpaceClaim->Mechanical geometry accuracy/tolerance problem | sultzan | ANSYS Meshing & Geometry | 0 | December 13, 2018 17:41 |
[snappyHexMesh] sHM refinement away from surface | nholt | OpenFOAM Meshing & Mesh Conversion | 1 | June 14, 2016 14:36 |
[snappyHexMesh] sHM with cyclic patch on stl geometry | johannesk | OpenFOAM Meshing & Mesh Conversion | 2 | August 21, 2009 09:08 |
