[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? |
March 1, 2015, 09:13 |
Klaus
Rep Power: 22 |
I'd like to speedup meshing with snappyhexmesh. Everything works fine, when I run it on one core but my i7 offers "8" so let's make use of them. I had a look at the motorbike case, used the decomposepardict... there are no errors but snappyhexmesh doesn't create a mesh. Where's the error? This is my Allmesh script: #!/bin/sh # Determine OpenFOAM version OF_MAJOR=`echo $WM_PROJECT_VERSION | cut -d'.' -f1` OF_MINOR=`echo $WM_PROJECT_VERSION | cut -d'.' -f2` # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions # Set variable to distinguish between OF 2.2 and older versions if [ $OF_MAJOR -le 2 -a $OF_MINOR -le 1 ]; then OLD=1 else OLD=0 fi ## Make 3D mesh in slab of cells. cd airfoil_snappyHexMesh runApplication blockMesh > output/1-blockMesh.log 2>&1 if [ $OLD -eq "1" ]; then runApplication surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/airfoil.stl airfoil > output/2-surfaceFeatureExtract.log 2>&1 else runApplication surfaceFeatureExtract > output/2-surfaceFeatureExtract.log 2>&1 fi # THIS WORKS # running snappyhexmesh on one core of the i7 processor #runApplication snappyHexMesh -overwrite > output/3-snappyHexMesh.log 2>&1 #rm -f 0/* # THIS DOESN'T WORK # running snappyhexmesh on 8 cores of the i7 processor runApplication decomposePar runParallel snappyHexMesh 8 -overwrite > output/3-snappyHexMesh.log 2>&1 rm -f 0/* runApplication reconstructParMesh -constant This is my decomposepardict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 8; method hierarchical; //method ptscotch; simpleCoeffs { n (4 2 1); delta 0.001; } hierarchicalCoeffs { n (4 2 1); delta 0.001; order xyz; } manualCoeffs { dataFile "cellDecomposition"; } // ************************************************** *********************** // |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 15:15 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Issue with arbitrary Lagrangian-Eulerian method and mesh optimization | mikolchon | Main CFD Forum | 0 | August 16, 2014 15:50 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
