[Gmsh] Extruded Meshing fails (Linear search / could not find extruded vertex)
Old   September 3, 2012, 12:09
Default Extruded Meshing fails (Linear search / could not find extruded vertex)
Ijazu
Ijazu is on a distinguished road
Hello everybody,
I am currently trying to set up a case for OpenFOAM using gmsh for the first time for creating the geometry. It includes extruded geometry which is then being copied and mirrored. But there seems to be a problem when meshing it. After meshing a couple of surfaces, gmsh prompts
Info : Meshing surface 1484 (extruded)
Info : Linear search for (8.539101721554962, 1.460898278445038, -10)
Error : Could not find extruded vertex (8.539101721554962, 1.460898278445038, -10) in surface 1484
three times. When meshing the volumes, the same error
Info : Meshing volume 62 (extruded)
Info : Linear search for (1.59871276638453, -0.1373313127625496, -10)
Error : Could not find extruded vertex (1.59871276638453, -0.1373313127625496, -10)
occurs many times, 515 times in total. This results in strange holes in the geometry, leading to missing cells.
I tried different meshing algorithms, with no success. I am using gmsh 2.5.1 on Ubuntu 12.04.
I attached the geo-file, a second file being included, the error log and an image showing the missing cells. I also added the .gmsh-options file. I would be very thankful for any help solving this problem.
Regards
Ijazu is offline   Reply With Quote
Old   March 18, 2015, 07:15
X Meng
mxylondon is on a distinguished road
Hellow Ijazy, have you solved this problem? It seems I have the same problem now. Really confused.
mxylondon is offline   Reply With Quote
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 06:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Gambit map meshing scheme Juliana P FLUENT 2 October 30, 2005 15:59
Best Search algorithm for Unstructured Meshing? Dinesh Godavarty Main CFD Forum 3 September 3, 2003 13:16
