May 5, 2015, 09:03 |
Moving Mesh
Mehdi
Dear Foamers;
I am going to simulate deformation of a rubber pipe when a newtonian fluid (water) is flowing through. The pipe is considered viscoelastic. I want to know how could I create mesh (is the movingMesh utility appropriate?) and what type of mesh shall I use (is the movingMesh ok? Or I should use a meshless approach?)? What boundary conditions should I use? Which type of applications is the best for this problem? Thanks in advance Mehdi |
December 13, 2015, 14:08 |
Well Dear Mehdi,
You have asked a very general question! You have to be very more specific about what you are doing and what exactly is the geometry of your problem. Your problem is a FSI problem and not actually very easy to get over with. First of all you have to have a good understanding of OpenFOAM FSI solvers, try solving some simple tutorials and then may try it on your own problem. You may take a look at this video: https://www.youtube.com/watch?v=Te9LCqPgT-Q Best.
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
movingmesh, viscoelastic |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Trying to set up Moving Mesh Problem | dreamchaser | CFX | 5 | December 15, 2014 00:07 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
