[blockMesh] New to Openfoam and troubles with blockMesh!
Old   May 22, 2018, 06:41
Exclamation New to Openfoam and troubles with blockMesh!
Timo
aerospacious is on a distinguished road
Dear Foamers!
I am very new to openFoam and run in some troubles with blockMesh. I've already done the cavity and hole in plate tutorial and I'm currently trying to generate my own mesh using the blockMeshDict file.
Unfortunately when I run it it gives the following error:
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'blocks' on line 42 and ending at line 114"
my blockmesh script is:
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (-5, -5,  5) // 0
    ( 0, -5,  5) // 1
    ( 5, -5,  5) // 2
    ( 5,  0,  5) // 3
    ( 0,  0,  5) // 4
    (-5,  0,  5) // 5
    (-5, -5,  0) // 6
    ( 0, -5,  0) // 7
    ( 5, -5,  0) // 8
    ( 5,  0,  0) // 9
    ( 0,  0,  0) // 10
    (-5,  0,  0) // 11
    (-5, -5, -5) // 12
    ( 0, -5, -5) // 13
    ( 5, -5, -5) // 14
    ( 5,  0, -5) // 15
    ( 0,  0, -5) // 16
    (-5,  0, -5) // 17
blocks
    hex(0 1 4  5  6  7  10 11) (10 10 10) simpleGrading (1 1 1)
    hex(1 2 3  4  7  8  9  10) (10 10 10) simpleGrading (1 1 1)
    hex(6 7 10 11 12 13 16 17) (10 10 10) simpleGrading (1 1 1)
    hex(7 8 9  10 13 14 15 16) (10 10 10) simpleGrading (1 1 1)
edges
boundary
    inlet
        type wall;
        faces
            (0 6  11 5)
            (6 12 17 11)
    outlet
        type wall;
        faces
            (2 8  9  3)
            (8 14 15 9)
    top
        type wall;
        faces
            (5  4  10 11)
            (4  3  9  10)
            (11 10 16 17)
            (10 9  15 16)
    bottom
        type wall;
        faces
            (0 1 7  6)
            (1 2 8  7)
            (6 7 13 12)
            (7 8 14 13)
    frontAndBack
        type empty;
        faces
            (0  1  4  5)
            (1  2  3  4)
            (12 13 16 17)
            (13 14 15 16)
mergePatchPairs
The geometry I try to create is shown in the attached image.
Thanks in advance for everyone's help
Timo
aerospacious is offline   Reply With Quote
Old   May 23, 2018, 03:56
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
My guess would be the comma's in the vertices section, try this instead:
vertices
    (-5 -5  5) // 0
    ( 0 -5  5) // 1
    ( 5 -5  5) // 2
    ( 5  0  5) // 3
    ( 0  0  5) // 4
    (-5  0  5) // 5
    (-5 -5  0) // 6
    ( 0 -5  0) // 7
    ( 5 -5  0) // 8
    ( 5  0  0) // 9
    ( 0  0  0) // 10
    (-5  0  0) // 11
    (-5 -5 -5) // 12
    ( 0 -5 -5) // 13
    ( 5 -5 -5) // 14
    ( 5  0 -5) // 15
    ( 0  0 -5) // 16
    (-5  0 -5) // 17
tomf is offline   Reply With Quote
Old   May 23, 2018, 04:21
Timo
Thanks for the reply Tom, but unfortunately that does not work.
It gives the error at 'blocks' so I would assume I did something wrong there, but just can't see what (probably overlooking some rule I should have applied).
Old   May 23, 2018, 04:41
Tom Fahner
Ok, I just ran a test.
You are right that my suggestion did not solve the original issue, but it is necessary. The actual thing that goes wrong is there is a space missing after hex. This works, but generates an inside-out error. I guess you should check your order for the blocks to correspond with the order OpenFOAM expects:
    hex (0 1 4  5  6  7  10 11) (10 10 10) simpleGrading (1 1 1)
    hex (1 2 3  4  7  8  9  10) (10 10 10) simpleGrading (1 1 1)
    hex (6 7 10 11 12 13 16 17) (10 10 10) simpleGrading (1 1 1)
    hex (7 8 9  10 13 14 15 16) (10 10 10) simpleGrading (1 1 1)
Old   May 23, 2018, 04:45
Timo
You're awesome Tom!
That helped a lot. I already figured out the inside out error yesterday so I just ran it without problems.
Thanks again!
blockmesh, error, primitiveentry
Openfoam tutorials missing benediktus OpenFOAM Running, Solving & CFD 2 October 6, 2016 16:55
Multiregion BlockMesh Run Problem EFoster2 OpenFOAM Running, Solving & CFD 2 April 2, 2014 08:52
Install troubles on fedora yoshimitsuspeed OpenFOAM 1 July 20, 2011 02:49
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 12:59
OpenFOAM 14 parallel troubles msrinath80 OpenFOAM Running, Solving & CFD 14 July 5, 2007 04:51
