[Gmsh] OpenFoam Error Message: "no cells read from file .msh"
Old   June 13, 2015, 17:04
Cool OpenFoam Error Message: "no cells read from file .msh"
Massachusetts
kayla1994 is on a distinguished road
Hello all.
I've just made my first 2d mesh with GMSH i think it's corretly written.
Now i try to load it to OpenFoam but it returns me this error:
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)
my mesh is 2D.
Does anyone know the problem?
Thanks
this is my .geo:
// Gmsh project created on Sat Jun 13 11:37:29 2015
Point(1) = {1, 0, 0, 1};
Point(3) = {0.99572, 0.00057, 0, 0.0001};
Point(5) = {0.98296, 0.00218, 0, 0.0001};
Point(6) = {0.96194, 0.00463, 0, 0.0001};
Point(7) = {0.93301, 0.0077, 0, 0.0001};
Point(8) = {0.89668, 0.01127, 0, 0.0001};
Point(9) = {0.85355, 0.01522, 0, 0.0001};
Point(10) = {0.80438, 0.01945, 0, 0.0001};
Point(11) = {0.75, 0.02384, 0, 0.0001};
Point(12) = {0.69134, 0.02823, 0, 0.0001};
Point(13) = {0.62941, 0.03247, 0, 0.0001};
Point(14) = {0.56526, 0.03638, 0, 0.0001};
Point(15) = {0.5, 0.03978, 0, 0.0001};
Point(16) = {0.43474, 0.04248, 0, 0.0001};
Point(17) = {0.37059, 0.04431, 0, 0.0001};
Point(18) = {0.33928, 0.04484, 0, 0.0001};
Point(19) = {0.30866, 0.04509, 0, 0.0001};
Point(20) = {0.27886, 0.04504, 0, 0.0001};
Point(21) = {0.25, 0.04466, 0, 0.0001};
Point(22) = {0.22221, 0.04397, 0, 0.0001};
Point(23) = {0.19562, 0.04295, 0, 0.0001};
Point(24) = {0.17033, 0.04161, 0, 0.0001};
Point(25) = {0.14645, 0.03994, 0, 0.0001};
Point(26) = {0.12408, 0.03795, 0, 0.0001};
Point(27) = {0.10332, 0.03564, 0, 0.0001};
Point(28) = {0.08427, 0.03305, 0, 0.0001};
Point(29) = {0.06699, 0.03023, 0, 0.0001};
Point(31) = {0.05156, 0.0272, 0, 0.0001};
Point(32) = {0.03806, 0.02395, 0, 0.0001};
Point(33) = {0.02653, 0.02039, 0, 0.0001};
Point(34) = {0.01704, 0.01646, 0, 0.0001};
Point(35) = {0.00961, 0.01214, 0, 0.0001};
Point(36) = {0.00428, 0.00767, 0, 0.0001};
Point(37) = {0.00107, 0.00349, 0, 0.0001};
Point(38) = {0, 0, 0, 0.0001};
Point(39) = {0.00107, -0.00349, 0, 0.0001};
Point(40) = {0.00428, -0.00767, 0, 0.0001};
Point(41) = {0.00961, -0.01214, 0, 0.0001};
Point(42) = {0.01704, -0.01646, 0, 0.0001};
Point(43) = {0.02653, -0.02039, 0, 0.0001};
Point(44) = {0.03806, -0.02395, 0, 0.0001};
Point(45) = {0.05156, -0.0272, 0, 0.0001};
Point(46) = {0.06699, -0.03023, 0, 0.0001};
Point(47) = {0.08427, -0.03305, 0, 0.0001};
Point(48) = {0.10332, -0.03564, 0, 0.0001};
Point(49) = {0.10332, -0.03564, 0, 0.0001};
Point(50) = {0.12408, -0.03795, 0, 0.0001};
Point(51) = {0.14645, -0.03994, 0, 0.0001};
Point(52) = {0.17033, -0.04161, 0, 0.0001};
Point(53) = {0.19562, -0.04295, 0, 0.0001};
Point(54) = {0.22221, -0.04397, 0, 0.0001};
Point(55) = {0.25, -0.04466, 0, 0.0001};
Point(56) = {0.27886, -0.04504, 0, 0.0001};
Point(57) = {0.30866, -0.04509, 0, 0.0001};
Point(58) = {0.33928, -0.04484, 0, 0.0001};
Point(59) = {0.33928, -0.04484, 0, 0.0001};
Point(60) = {0.37059, -0.04431, 0, 0.0001};
Point(61) = {0.43474, -0.04248, 0, 0.0001};
Point(62) = {0.5, -0.03978, 0, 0.0001};
Point(63) = {0.56526, -0.03638, 0, 0.0001};
Point(64) = {0.62941, -0.03247, 0, 0.0001};
Point(65) = {0.69134, -0.02823, 0, 0.0001};
Point(66) = {0.75, -0.02384, 0, 0.0001};
Point(67) = {0.80438, -0.01945, 0, 0.0001};
Point(68) = {0.85355, -0.01522, 0, 0.0001};
Point(69) = {0.89668, -0.01127, 0, 0.0001};
Point(70) = {0.93301, -0.0077, 0, 0.0001};
Point(71) = {0.96194, -0.00463, 0, 0.0001};
Point(72) = {0.98296, -0.00218, 0, 0.0001};
Point(73) = {0.99572, -0.00057, 0, 0.0001};
Spline(1) = {38, 37, 36, 35, 34, 33, 32, 31, 29, 28, 27, 26, 25, 24, 23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 3, 1, 73, 72, 71, 70, 69, 68, 67, 66, 65, 64, 63, 62, 61, 60, 58, 57, 56, 55, 54, 53, 52, 51, 50, 48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38};
Point(74) = {7, 5, 0, 1.0};
Point(75) = {7, -5, 0, 1.0};
Point(76) = {-7, -5, 0, 1.0};
Point(77) = {-7, 5, 0, 1.0};
Point(78) = {7, 0.5, 0, 1.0};
Point(79) = {7, -0.5, 0, 1.0};
Point(80) = {0, 0, 0, 0.0001};
Point(81) = {0, 0.5, 0, 1.0};
Point(82) = {0, -0.5, 0, 1.0};
Point(83) = {-0.5, 0, 0, 1.0};
Line(2) = {76, 77};
Line(3) = {77, 74};
Line(4) = {74, 78};
Line(5) = {78, 81};
Line(6) = {82, 79};
Line(7) = {79, 75};
Line(8) = {75, 76};
Line(9) = {78, 79};
Circle(10) = {81, 80, 83};
Circle(11) = {83, 80, 82};
Line Loop(12) = {2, 3, 4, 5, 10, 11, 6, 7, 8};
Plane Surface(13) = {12};
Line Loop(14) = {5, 10, 11, 6, -9};
Line Loop(15) = {1};
Plane Surface(16) = {14, 15};
Physical Line("Left") = {2};
Physical Line("Top") = {3};
Physical Line("Right") = {4, 9, 7};
Physical Line("Bottom") = {8};
Physical Line("Airfoil") = {1};
kayla1994 is offline   Reply With Quote
Old   July 13, 2015, 09:26
KateEisenhower is on a distinguished road
Hi Kayla,
OpenFOAM can only handle 3D grids. You have to extrude your 2D mesh in gmsh before you can work with it.
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
