[snappyHexMesh] Running snappyHexMesh in parallel - optimizing
Like Tree2Likes
  • 2 Post By Antimony
Old   December 29, 2017, 08:35
Default Running snappyHexMesh in parallel - optimizing
Peter Hess
peterhess is on a distinguished road
Hello!
I am facing a problem here using snappyHexMesh in parallel...
Steps made in my case are:
- blockMesh (structured Mesh)
- decompose (hierarchical)
- snappyHexMesh (in parallel)
Everything works actually fine.
Mesh size about 400 000 Cells.
The Mesh has a complex geometry in the center of the middle.
The decompose sparatestheMesh allready generated by blockMesh since no snappyHexMesh avaliable yet.
That means the cells are equally devided on the processors.
snappyHexMesh in parallel is using the Mesh generated by blockMesh and separated by decompose.
Because of the complex geometry in the middle of the Mesh, the cores loads during snappyHexMesh become different.
The cores responsable for Meshing the complex geometry have more to do than the others.
Cores time (sec)
4 --- 942
6 --- 881
7 --- 824
8 --- 696
9 --- 703
12 -- 877
As we can see the snappyHexMesh needs less time to 8 cores then more time!
How could I let the loads (number of cells) during the snappyHexMesh changes and optimize itself to run snappyHexMesh faster (equal load for every core).
Sure I can separate my blockMesh-Mesh manaully during the decompose step, but I cant separate them perfectly, cause I dont know in this step, how much cells per every core are needed.
Hardware:
IBM X3850 M2 - 4 X 4 cors - 3Ghz
RAM 32 GB
Ubuntu 17.10 - openFoam 5.0
Regards
Peter
peterhess is offline   Reply With Quote
Old   January 2, 2018, 22:11
Antimony is on a distinguished road
I had posted on this a couple of years back (https://www.cfd-online.com/Forums/op...optimally.html)
Instead of hierarchical for your decomposition method, choose scotch. The advantage with scotch is that it figures out the load on each processor for you and you do not need to specify anything.
While the initial decomposition (when using scotch) maybe similar to the hierarchical method, in subsequent iterations (feature/surface/region refinement steps) of snappyHexMesh, the scotch algorithm will do load balancing.
To see that, you can see the processor boundaries at the start of snappyHexMesh and at the end of snappyHexMesh. They will be different.
Hope this helps
Cheers,
Antimony
Juleschocolat and issssc like this.
Antimony is offline   Reply With Quote
Old   January 3, 2018, 02:54
Peter Hess
Thanks Antimony
I did not notice that. I will try.
Regards
Peter
PS: Yes u r right. Probleme solved. Thanks a lot!
snappyhexfoam decompose
[snappyHexMesh] Running snappyHexMesh in parallel creates new time directories hconel OpenFOAM Meshing & Mesh Conversion 5 September 27, 2022 15:20
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 04:38
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 11:55
Fluent 14.0 file not running in parallel mode in cluster tejakalva FLUENT 0 February 4, 2015 07:02
