[Commercial meshers] ansysToFoam
Old   February 7, 2011, 05:22
Default ansysToFoam
RalphS is on a distinguished road
I have a problem. I want to use ansysToFoam, but the application doesn't run. After "Create Time" appears on the display nothing happens ...
Can someone help me?
Or some other hints to convert a mesh, produce with TurboGrid?
case> ansysToFoam test.gtm
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.1-03e7e056c215
Exec : ansysToFoam test.gtm
Date : Feb 07 2011
Time : 11:12:40
Host : pc6931
PID : 20129
Case : /...
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
RalphS is offline   Reply With Quote
Old   February 7, 2011, 19:13
Scott
scott is on a distinguished road
I'd try exporting as a .msh file in ASCII (search the forums to find out how) and use fluentMeshToFoam
.gtm is not supported as far as I am aware for ansysToFoam, it is for .inp I think. Feel free to correct me if I am wrong.
Hope this helps!
Scott
scott is offline   Reply With Quote
Old   February 7, 2011, 22:59
Kurne
kurne is on a distinguished road
Dear RalphS
Convert the mesh from TurboGrid to fluent mesh format which will give the mesh in .msh extension say fluent.msh. Copy this fluent.msh file in to your directory and use command fluent3DMeshToFoam fluent.msh.
It will work.If still any problem then we will see it.
Take Care
Simulation Is Determination Of Imagination Towards Approximation ®
Best Regards
Mubeen K Kurne
kurne is offline   Reply With Quote
Old   February 8, 2011, 07:45
Thanks,
I use ansys turbo grid 12.0.
I didn't found out, how I am able to export to an Fluent .msh Mesh file.
Old   December 7, 2012, 15:31
Eric
EVBUCF is on a distinguished road
I know this is an old thread but I am interested in this same conversion. I have a .gtm mesh that needs to be converted for use in openFoam. Anyone know how to get this done?
EVBUCF is offline   Reply With Quote
Old   December 14, 2015, 07:34
Jack
Jack001 is on a distinguished road
I'm also interested in this. I'm not sure how to convert turbo grid meshes into a format that can be converted to an openFoam readable mesh. If .msh is what I need how do I export a .msh file from turbo grid? Thanks!
Jack001 is offline   Reply With Quote
Old   December 14, 2015, 08:46
Olivier
olivierG is on a distinguished road
hello,
Export in .msh (ascii format !). Import with fluent3DToFoam.
If you can't export as a .msh, send to Fluent, then save as .cas (still in ascii !). You can import the .cas with fluent3DToFoam.
regards,
olivier
olivierG is offline   Reply With Quote
Old   December 15, 2015, 16:02
Jack
Thanks for your response - I could only output files as .cgns and .gtm I have no idea how to open these again in turbo grid or to convert the mesh to something my solver (openFoam 2.3.1) can read...
Old   January 23, 2016, 19:44
Jack
Can someone please offer any advice on this issue? Its driving me nuts!
[Commercial meshers] ansysToFoam >> which file should I use? vitorspadeto OpenFOAM Meshing & Mesh Conversion 0 May 8, 2014 22:23
[Commercial meshers] ansysToFoam stops Mathias-TU OpenFOAM Meshing & Mesh Conversion 20 October 17, 2013 03:01
