[snappyHexMesh] snappyHexMesh matches wrong cells to CellZone
Old   July 8, 2015, 04:25
Default snappyHexMesh matches wrong cells to CellZone
Marcel Bornstein
Siegunn is on a distinguished road
Hello Foamers,
i`m new with snappyHexmesh and i'm trying to mesh a small tubelike structure with a Mesh. This structure is defined by a (multiple) stl-file and is extracted by its corresponding cellZone created by snappyHexMesh. The Surface is closed (surfaceCheck).
Everything works fine except for some frontfaces (see attached picture). It looks like snappy matches some cells of the surrounding mesh to the cellZone. As you can see it does not happen to every frontface.
I tried to adjust the size of the basic mesh and changed the refinement parameters. But this did not help. It would be glad to get some hints from some more experienced people (The dicts of blockMesh and snappy are attached below).
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
ap  20;
an -20;
bp  40;
bn -40;
vertices
    ( $an $an $bn)
    ( $ap $an $bn)
    ( $ap $ap $bn)
    ( $an $ap $bn)
    ( $an $an $bp)
    ( $ap $an $bp)
    ( $ap $ap $bp)
    ( $an $ap $bp)
blocks
    hex (0 1 2 3 4 5 6 7) (40 40 80) simpleGrading (1 1 1)
edges
boundary
    fixedWalls
        type wall;
        faces
            (0 4 7 3)
            (2 6 5 1)
            (1 5 4 0)
         (4 5 6 7)
        (3 7 6 2)
         (0 3 2 1)
 /*   front
        type patch;
        faces
     (4 5 6 7)
        back
        type patch;
        faces
        (0 3 2 1)
mergePatchPairs
|  \\    /   O peration     | Version:  2.2.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
ref 5;
// Which of the steps to run
castellatedMesh true;
snap            false;
addLayers       false;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    NMR.stl
        type    triSurfaceMesh;
    name    NMR;
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 700000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 1500000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 25;
    // Allow a certain level of imbalance during refining
    // (since balancing is quite expensive)
    // Expressed as fraction of perfect balance (= overall number of cells /
    // nProcs). 0=balance always.
    maxLoadUnbalance 0.10;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 1;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
           file        "NMR.eMesh";
           level       $ref;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
    NMR
            level       (3 $ref);
            faceZone schleife;
            cellZone schleife;
            cellZoneInside inside;
        //  faceType boundary;
    // Resolve sharp angles
    resolveFeatureAngle 60;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
/*    schleife
            mode        inside;
            levels      ((1E15 $ref));
//              mode distance;
//              levels ( (0.0005 4) (0.001 3) (0.002 2) );
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (0 0 0);
  //  locationInMesh (0.001 1e-05 -1e-05);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces false;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 2;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 2; // 1.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 400;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 6;
    //- Highly experimental and wip: number of feature edge snapping
    //  iterations. Leave out altogether to disable.
    //  Do not use here since mesh resolution too low and baffles present
    // Number of feature edge snapping iterations. (disabled if omitted).
          nFeatureSnapIter 3;
    // Detects (geometric only) features by sampling the surface (default=false).
          implicitFeatureSnap false
     // Use features in castellatedMeshControls (default = true).
          explicitFeatureSnap true
        // For explicitFeatureSnap, detect features between multiple surfaces (default = false)
          multiRegionFeatureSnap true;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
    // Expansion factor for layer mesh
    expansionRatio 1.0;
    // Wanted thickness of final added cell layer. If multiple layers
    // is the
    // thickness of the layer furthest away from the wall.
    // Relative to undistorted size of cell outside layer.
    // is the thickness of the layer furthest away from the wall.
    // See relativeSizes parameter.
    finalLayerThickness 0.3;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 0.1;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 0;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 30;
    // Maximum number of snapping relaxation iterations. Should stop
    nRelaxIter 3;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 2;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedianAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 65;
    //- Max skewness allowed. Set to <0 to disable.
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 100;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol 1e-15;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre. This has to be a positive number for tracking
    //  to work. Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality -1; // 1e-30;
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //- and face centre triangles normal
    minTwist 0.01;
    //- minimum normalised cell determinant
    //- 1 = hex, <= 0 = folded or flattened illegal cell
    minDeterminant 0.001;
    //- minFaceWeight (0 -> 0.5)
    minFaceWeight 0.05;
    //- minVolRatio (0 -> 1)
    minVolRatio 0.01;
    //must be >0 for Fluent compatibility
    minTriangleTwist -1;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 5;
    //- amount to scale back displacement at error points
    errorReduction 0.75;
    // Optional : some meshing phases allow usage of relaxed rules.
    // See e.g. addLayersControls::nRelaxedIter.
    relaxed
        maxNonOrtho 75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
Siegunn is offline   Reply With Quote
Old   July 10, 2015, 12:32
Tim
Tim_Simon is on a distinguished road
Hi Siegunn,
I'm currently working on smth similiar. Meaning I have multiple closed surfaces that I want to write in cellZones. Have you tried to activate the refinementRegions and giving it at least the same level as the surface?
    refinementRegions     {  /*    schleife         {             mode        inside;             levels      ((1E15 $ref));     } */ //              mode distance; //              levels ( (0.0005 4) (0.001 3) (0.002 2) );               }
Just my first guess.
Tim_Simon is offline   Reply With Quote
Old   July 11, 2015, 02:47
Marcel Bornstein
Hi Tim,
this was the right hint Thank you very much. I was sure i tried everything, but obviously i didn't.
Old   July 11, 2015, 10:54
Tim
Hey,
glad that helped. Good luck for your simulation.
Greetings
Old   July 31, 2015, 05:10
Vineet Bhola
vineet_bhola is on a distinguished road
Hi Marcel/Tim,
When you say multiple stl file, do you guys mean that it is a single stl file with more than one patch defined in the file?
For example I have a stl file in form of closed cylinder. It has 3 faces/patches defined as entry, Exit and cylinder walls. But when I run snappy, all the faces go to the defaultfaces and These 3 patches are empty. Have you guys faced any similar issue
Thanks
Vineet
vineet_bhola is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 09:26
udf error srihari FLUENT 1 October 31, 2016 14:18
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
