[Salome] Precision in UNV to FOAM mesh conversion
Like Tree1Likes
  • 1 Post By richard_vega
Old   August 18, 2015, 13:25
Default Precision in UNV to FOAM mesh conversion
Richard Vega
richard_vega is on a distinguished road
I am able to use ideasUnvToFoam with ease to convert meshes I have created using Salome into OpenFOAM format. There is only one problem: when I look at the points file that gets created in the polyMesh folder, I find that it is writing coordinates with a maximum of 5 decimal places. Is there a way to increase this precision?
richard_vega is offline   Reply With Quote
Old   August 18, 2015, 14:50
Retired Super Moderator
Bruno Santos
Quick answer: In your case folder, "system/controlDict" -> "writePrecision" - or in "writeFormat" use "binary" format for full precision... although it's binary.
Old   August 19, 2015, 10:38
Richard Vega
Thank you very much for the quick reply. It worked! For some reason I did not associate the controlDict with the mesh converters. I thought it was just for the solver to write the field variables. Thank you again!!
wyldckat likes this.
ideasunvtofoam
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[Commercial meshers] fluent mesh conversion to foam sangram OpenFOAM Meshing & Mesh Conversion 1 November 14, 2016 07:14
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
