[Other] Creating a suction hole in a pipe geometry.
Old   May 27, 2015, 17:16
Default Creating a suction hole in a pipe geometry.
despodan
Daneish is on a distinguished road
Send a message via Skype™ to Daneish
I'm new to this forum. I would like some advice for creating a geometry and mesh for a suction hole (to remove odour) from a sewer pipe. I have created and meshed the sewer pipe already but now i'm interested in creating that suction hole. I have attached my bockmeshdict file for the sewer pipe. Any advice or ideas on how to approach this would be greatly appreciated.
Whats the best option to do this? Should i continue using blockMesh or use Salome for example.
Many thanks,
Daneish
File Type: gz blockMeshDict.tar.gz (917 Bytes, 7 views)
Daneish is offline   Reply With Quote
Old   August 20, 2015, 16:55
cutter is on a distinguished road
maybe this thread helps: http://www.cfd-online.com/Forums/ope...apability.html.
Cutter
cutter is offline   Reply With Quote
Old   August 21, 2015, 05:04
despodan
Hello Mr. Cutter
I will check out this alternative method. Thank you for this direction.
Best,
Daneish
[ANSYS Meshing] Pump suction pipe simulation hamza mohamed ANSYS Meshing & Geometry 0 June 17, 2017 09:48
Vertical Suction Pipe Modeling At simple Pump sump Mesh33 FLOW-3D 2 August 3, 2016 02:24
[DesignModeler] POROUS Media inside a pipe geometry creation gauravchauhan ANSYS Meshing & Geometry 0 April 12, 2014 04:15
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
creating model for pipe system???? keng ANSYS Meshing & Geometry 11 November 14, 2011 10:10
