[Other] Problem with patches/cells on edge with multi-region mesh |
Vineet Bhola
Rep Power: 10 ![]() |
Hi Guys,
I am working with a multi-Region mesh with a gas as a cylindrical volume surrounded by a solid container. The boundary seems smooth and fine but only around the edge of clinder, there are some cells which should have belonged to the other side of the boundary. You can see there are 5 patches of solid written into abgas boundary and 3 from gas written into solid. I am attaching rest of the pics and the scripts in the comments below. Thanks Vineet |
Vineet Bhola
Here are the pics of solid and scripts. (I had it compressed as .rar and changed the Format to .zip. I am not sure if that works fine)
#3 | |
Vineet Bhola
I have found a probable reson for this problem. I am attaching the ouput of
checkMesh -region solid -latestTime -allGeometry Quote:
Vineet Bhola
Has anyone faced a similar problem before? It seems like I am talking to myself. I just speculate that it was the reason...I have not found any solution (Infact not even sure concave faces/cells are really creating the problem)
Hi Vineet,
Can we have a look at your snappyHexMeshDict ? |
Vineet Bhola
you can check out the whole case Folder in the attachment file. Blockmeshdict and Snappyhexmeshdict are in there
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 19:34 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
