[Other] Visualize nonOrthoFaces set
Like Tree5Likes
  • 5 Post By r2d2
Old   November 28, 2006, 09:33
Default Visualize nonOrthoFaces set
Radu Mustata
r2d2 is on a distinguished road
Is there a way of visualising a set of faces? I have a large mesh generated with blockMesh but with quite a few non-orthogonal faces and I would like to locate them...before running the code and in the (potentially) subsquent trouble.
BTW, I think I´ve seen this before, but can anyone tell me what the "severe non-orthogonality for face *** " means...just that the line that goes through the center of the cells is not perpendicular to the face that separates them...and should I be very concerned, or simply play with discretization and/or orthogonal correctors?
I say that, because I guess that if e.g. blockMeshDict has defined edges that belong to, say, 3 or 5 blocks a a time, then one will get these non-ortogonality situations.
Cheers,
Radu
r2d2 is offline   Reply With Quote
Old   November 28, 2006, 10:43
Default Never mind the first question.
Radu Mustata
Never mind the first question...after digging a bit I saw that one can vie that with foamToVTK -faceSets..and paraview...the second part, though...
Radu
Old   September 16, 2015, 02:21
KateEisenhower is on a distinguished road
Originally Posted by r2d2 View Post
... BTW, I think I´ve seen this before, but can anyone tell me what the "severe non-orthogonality for face *** " means...just that the line that goes through the center of the cells is not perpendicular to the face that separates them...
You're right.
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
[mesh manipulation] mirrorMesh and undoing the joining of patches chegdan OpenFOAM Meshing & Mesh Conversion 3 October 21, 2015 08:09
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 02:24
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Ibm java gcc rrr OpenFOAM Installation 2 December 30, 2005 04:18
