[mesh manipulation] mergePatchPairs with multiple areas |
Björn N.
Rep Power: 13 ![]() |
Hi together!
I try to use mergePatchPairs to arrange a block-structured grid. It looks somehow like this: block2 | block5 |block4 ------------------------------------ block1 | oldBlock |block3 -------------(sym.)--------------- The idea is that the blocks 1-5 have a coarser grid. When I use mergePatchPairs like this Code:
mergePatchPairs ( (oldInlet A1East) (oldOutlet A3West) (oldTopbottom A5South) ) Code:
--> FOAM FATAL ERROR: Duplicate point found in cut face. Error in the face cutting algorithm for global face 4(9160 9164 9165 9161) local face 4(13 12 18 19) Slave size: 25 Master size: 228 index: 10. block2 | block5 |block4 ----------x--------------x---------- block1 | oldBlock |block3 -------------(sym.)--------------- Can someone help me out? I searched the forum but didnt really find an answer. Is it possible to run mergePatchPairs twice? Thanks a lot in advance! Björn |
Björn N.
Just in case that somebody has similar problems. My work-around was the following: I merged the oldBlock, block1 and block3 with mergePatchPairs. Then I created a new case with block2, block5 and block4 and used mergeMeshes and stitchMesh to stitch the both cases together. In another case I used AMI boundaries to create the mesh.
duplicate, mergepatchpairs, multiple |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 16:22 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
[blockMesh] BlockMeshDict with multiple hex blocks mergePatchPairs | prousa | OpenFOAM Meshing & Mesh Conversion | 1 | May 14, 2009 23:42 |
