[mesh manipulation] extrudeToRegionMesh - direction into the domain |
June 10, 2016, 06:54 |
Nicklas Linder
Rep Power: 13 |
Hi guys,
I want to generate a Region at a boundary tu use the filmModel. The tutorial cylinder generates a one cell thick region by extrudeToRegionMesh which points into the domain. OF v2.4.0: I set up a simple case with a sphere in the center of the domain and fluid around. I use topoSet to select the boundary faces and generate a faceZone. This faceZone is handed to extrudeToRegionMesh to generate the region. This basically works, but the region points into the sphere - so out of the domain. I tried to use "flip true" in the topoSet, but this did not help. I also switched manually the normal in constant/polyMesh/faceZone. This generates the region in the domain, but then, the mapping of the two regions does not happen. So I am stuck here, does anyone had the same experience and an idea for a solution? Thanks Nicklas |
extrudetoregionmesh |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
confusion in specifying domain flow direction and results | ashwani.thakur | CFX | 4 | February 28, 2015 06:45 |
Heat transfer within a porous domain | rbezerra | CFX | 5 | January 9, 2015 05:06 |
Recommended domain size in Z direction | aamer | Main CFD Forum | 0 | December 22, 2010 05:57 |
