[blockMesh] Trouble using blockMesh for axisymmetric geometry |
February 8, 2016, 20:41 |
Tommy Mello
Rep Power: 11 |
All,
I'm having trouble using blockMesh for a simple axisymetric geometry. I have collapsed two edges per User Guide 5.3.3. I also rotated the geometry to straddle the XY plane. I am unable to generate a single cell thickness as shown in the image. Please note the angle here is set to 45 degrees for easy viewing, the issue shows up when a small angle is used (<5 degrees). I am able to create an axisymmetric mesh using the Main ContribEample. However, my geometry should be along X and I prefer the vertex numbering from the user manual. Where am I going wrong here? I am obviously missing something important when collapsing edges for an axisymmetric blockMesh. Thanks! Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (1.1 0 0) (1.1 0.095 -0.095) (0 0.095 -0.095) (0 0.095 0.095) (1.1 0.095 0.095) ); blocks ( hex (0 1 2 3 4 5 5 4) (20 10 1) simpleGrading (1 1 1) ); edges ( ); boundary ( ); mergePatchPairs ( ); // ************************************************************************* // |
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh | colinB | OpenFOAM Meshing & Mesh Conversion | 8 | January 22, 2012 10:32 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
[snappyHexMesh] stl geometry trouble | vaina74 | OpenFOAM Meshing & Mesh Conversion | 1 | December 7, 2010 05:11 |
[blockMesh] Trouble with blockMesh | kupiainen | OpenFOAM Meshing & Mesh Conversion | 40 | January 10, 2009 17:44 |
BlockMesh trouble | r2d2 | OpenFOAM Pre-Processing | 2 | January 16, 2006 09:51 |
