[blockMesh] Trouble using blockMesh for axisymmetric geometry |
February 8, 2016, 20:41 |
Tommy Mello
Rep Power: 11 |
All,
I'm having trouble using blockMesh for a simple axisymetric geometry. I have collapsed two edges per User Guide 5.3.3. I also rotated the geometry to straddle the XY plane. I am unable to generate a single cell thickness as shown in the image. Please note the angle here is set to 45 degrees for easy viewing, the issue shows up when a small angle is used (<5 degrees). I am able to create an axisymmetric mesh using the Main ContribEample. However, my geometry should be along X and I prefer the vertex numbering from the user manual. Where am I going wrong here? I am obviously missing something important when collapsing edges for an axisymmetric blockMesh. Thanks! Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (1.1 0 0) (1.1 0.095 -0.095) (0 0.095 -0.095) (0 0.095 0.095) (1.1 0.095 0.095) ); blocks ( hex (0 1 2 3 4 5 5 4) (20 10 1) simpleGrading (1 1 1) ); edges ( ); boundary ( ); mergePatchPairs ( ); // ************************************************************************* // |
February 8, 2016, 20:59 |
Tommy Mello
Rep Power: 11 |
The issue is in the vertex numbering which influences the local coordinate system used by blockMesh.
The vertex numbers should be changed such that x3 (referenced below) of the local coordinate system is in the direction of the unit cell and not as shown in the user manual 5.3.3. Code:
The local coordinate system is defined by the order in which the vertices are presented in the block definition according to: the axis origin is the first entry in the block definition, vertex 0 in our example; the x1 direction is described by moving from vertex 0 to vertex 1; the x2 direction is described by moving from vertex 1 to vertex 2; vertices 0, 1, 2, 3 define the plane x3 = 0; vertex 4 is found by moving from vertex 0 in the x3 direction; vertices 5,6 and 7 are similarly found by moving in the x3 direction from vertices 1,2 and 3 respectively. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (1.1 0 0) (1.1 0.095 -0.09499999999999999) (0 0.095 -0.09499999999999999) (0 0.095 0.09499999999999999) (1.1 0.095 0.09499999999999999) ); blocks ( hex (0 4 3 0 1 5 2 1) (20 1 40) simpleGrading (1 1 1) ); edges ( ); boundary ( ); mergePatchPairs ( ); // ************************************************************************* // |
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh | colinB | OpenFOAM Meshing & Mesh Conversion | 8 | January 22, 2012 10:32 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
[snappyHexMesh] stl geometry trouble | vaina74 | OpenFOAM Meshing & Mesh Conversion | 1 | December 7, 2010 05:11 |
[blockMesh] Trouble with blockMesh | kupiainen | OpenFOAM Meshing & Mesh Conversion | 40 | January 10, 2009 17:44 |
BlockMesh trouble | r2d2 | OpenFOAM Pre-Processing | 2 | January 16, 2006 09:51 |
