[blockMesh] error of blockMesh
Old   March 7, 2016, 05:25
Default error of blockMesh
Ping Chang
chpjz0391 is on a distinguished road
Hi to all
Which means this error of blockMesh?
| \\ / O peration | Version: 3.0.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0) //0
(0.4 0 0) //1
(0.4 0.2 0) //2
(0 0.2 0) //3
(0.6 0.2 0) //4
(0.6 0 0) //5
(1 0 0) //6
(1 0.2 0) //7
(1 1 0) //8
(0.6 1 0) //9
(0.4 1 0) //10
(0 1 0) //11
(0 0 0.01) //12
(0.4 0 0.01) //13
(0.4 0.2 0.01) //14
(0 0.2 0.01) //15
(0.6 0.2 0.01) //16
(0.6 0 0.01) //17
(1 0 0.01) //18
(1 0.2 0.01) //19
(1 1 0.01) //20
(0.6 1 0.01) //21
(0.4 1 0.01) //22
(0 1 0.01) //23
blocks
hex (0 1 2 3 12 13 14 15) (20 10 1) simpleGrading (1 1 1) //block 1
hex (3 2 10 11 15 14 22 23) (20 20 1) simpleGrading (1 1 1) //block 2
hex (2 4 9 10 14 16 21 22) (10 20 1) simpleGrading (1 1 1) // block 3
hex (4 7 8 9 16 19 20 21) (20 20 1) simpleGrading (1 1 1) //block 4
hex (5 6 7 4 17 18 19 16) (10 20 1) simpleGrading (1 1 1) //block 5
edges
boundary
outlet
type patch;
faces
(6 18 19 7)
inlet
type patch;
faces
(2 14 16 4)
upperWall
type wall;
faces
(11 10 22 23)
(10 9 21 22)
(9 8 20 21)
downWall
type wall;
faces
(0 12 13 1)
(1 13 14 2)
(5 4 16 17)
(5 17 18 6)
leftWall
type wall;
faces
(3 11 23 15)
(0 3 15 12)
rightWall
type wall;
faces
(7 19 20 8)
frontAndback
type emepty;
faces
(0 1 2 3)
(3 2 10 11)
(4 5 6 7)
(4 7 8 9)
(2 4 9 10)
(15 14 13 12)
(15 23 22 14)
(14 22 21 16)
(16 19 18 17)
(16 21 20 19)
mergePatchPairs
Basic statistics
Number of internal faces : 4
Number of boundary faces : 22
Number of defined boundary faces : 22
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list
--> FOAM FATAL ERROR:
Inconsistent number of faces between block pair 3 and 4
From function blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 217.
FOAM exiting
Below is my meshdic
Someone can help me?
Ping
chpjz0391 is offline   Reply With Quote
Old   March 7, 2016, 09:50
Antimony is on a distinguished road
This means that the number of divisions that you have specified for an edge (in this case the edge connecting vertices 4 & 7) are different in different blocks.
Note that the block numbering in blockMesh/OpenFOAM starts from 0 and not 1.
So, in the two blocks that have you have defined that have the edge made up by vertices 4 & 7, one has 10 divisions and the other has 20 divisions.
Correct that to be consistent and that problem will be solved.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   March 10, 2016, 00:21
Thumbs up Thank you very much, yeah the divisions are different.. Thanks again.
Ping Chang
Originally Posted by Antimony View Post
Cheers,
Antimony
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
[snappyHexMesh] Cylindrical blockmesh to Improve snappyHexMesh Results nicholas.jones OpenFOAM Meshing & Mesh Conversion 3 May 16, 2019 09:52
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
