[Other] Write out nonorthogonality and squness as fields?
Old   March 19, 2016, 20:23
Default Write out nonorthogonality and squness as fields?
roadRunner is on a distinguished road
Is it possible? Not just non-ortho faces but for all faces, so I can look at it in paraview.
Thank you,
beep-beep
roadRunner is offline   Reply With Quote
Old   March 21, 2016, 00:43
Antimony is on a distinguished road
Well, I am not sure about writing it as fields, but you can run checkMesh on your case and then use foamToVTK to convert the faceSets/cellSets to VTKs that can be viewed in Paraview.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   March 22, 2016, 08:35
Thank you for your reply.
Thaths true, but that only works for highly-nonorthogonal faces.
I would like to know this info for the entire mesh if possible, or at least for a range of nonorthogonality if that makes sense..
beep-beep
Old   March 23, 2016, 01:48
I actually stand corrected. Apparently you can do something of the sort that you mentioned using swak4Foam:
http://www.cfd-online.com/Forums/ope...tml#post387378
Hope this helps.
Cheers,
Antimony
