[mesh manipulation] a question about refineMesh
Old   June 22, 2011, 09:09
Default a question about refineMesh
liufang
fangliu is on a distinguished road
Hi everybody!
I' like using refineMesh to refime the mesh like below
but the result is like below
what should I do?
Thanks very much!
fangliu is offline   Reply With Quote
Old   June 22, 2011, 20:46
liufang
I have fund the answer, the refineMesh works well.The refined grids just like the first figure, but the paraview's display is not correct, The diagonal lines are of fictitious. I still do not know how to correct it.
Old   June 22, 2011, 20:59
liufang
Checking the "Use VTkPolyhedron", paraview will show the correct display.
Old   June 28, 2011, 05:29
stephane sanchi
openfoam_user is on a distinguished road
Where is located the "Use VTkPolyhedron" in paraFoam ?
Regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   June 28, 2011, 21:35
Default reply
liufang
If you compile "PV3FoamReader Module" correctly, the paraview's "Object Inspector" looks like figure below ,you can check "use VTKPolyhedron".
but if you failed to compile "PV3FoamReader Module", paraview can still work, the "Object Inspector" looks like figure below ,you can not check "use VTKPolyhedron", the display is not correct, but the grids are ok.
Old   September 5, 2011, 11:35
Francois
Fransje will become famous soon enough
Hi All,
OpenFOAM cannot use meshes with floating nodes, so no the, diagonals are not fictitious. Valid cell shapes recognized by OpenFOAM can be found here. Therefore, to correctly close the mesh shown in the first post, OpenFOAM will create triangles, which is consistent with the diagonals shown in paraview/paraFoam.
Kind regards,
Francois.
Fransje is offline   Reply With Quote
Old   October 31, 2011, 10:22
Default how I can refine a specific region?
giovanni silva
giovanni10 is on a distinguished road
Does anyone know how I can refine a specific region in a cavity for example?
Thanks!
giovanni10 is offline   Reply With Quote
Old   January 20, 2012, 16:14
ic3wall is on a distinguished road
Originally Posted by fangliu View Post
Hi everybody!
what should I do?
Thanks very much!
I have the exact OPPOSITE problem ... refineMesh doesn't add the diagonal, so two faces are orthogonal to another single face, which creates problems
Is there a switch somewhere in the refineMeshDict that I haven't seen ???
ic3wall is offline   Reply With Quote
Old   April 8, 2016, 08:21
Timm Severin
Astrodan is on a distinguished road
For whoever stumbles upon this, the above information seems to be incorrect (at least not anymore in OF-2.3.x). I created a small testcase, which consists of two vertically stacked blocks.
The lower block is then "refined" in 2 blocks. I visualised the result in paraview, once using VTKPolyhedra and once without, and further compared the visualisation with a plot in MATLAB, for which I directly exported the data from polyMesh/points and polyMesh/faces.
The result of the Matlab visualisation perfectly agrees with the VTKPolyhedral picture:
The paraFoam version not using VTKPolyhedra:
Also regarding the standard shapes linked, those are the ones recognised, but OF also supports arbitrary polyhedra (compare checkMesh output).
I also attach the testcase including my Matlab script for those interested.
Astrodan is offline   Reply With Quote
mesh adaption, refinemesh
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
checkMesh Errors after refineMesh mgdenno OpenFOAM 0 July 30, 2012 21:39
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
