[snappyHexMesh] Obtain a cellSet according to sHM refinement level
Old   April 23, 2016, 17:32
Default Obtain a cellSet according to sHM refinement level
Gianluca
gianlu.it is on a distinguished road
Dear All,
I have to refine a set of cells with the refineMesh utility. The cell set (called set_0) has to be defined as:
a bounding box (called topoSet_A) subtracted with another cell set (called set_B).
The criteria of set_B is the refinement level obtained after sHM castellated operation. Does somebody knows how to obtain the set_0, or at least the set_B?
My mesh pipeline is:
surfaceFeatureExtract
blockMesh
snappyHexMesh -dict system/snappyHexMesh.1 (dictionary with only castellated enabled)
topoSet (in order to obtain topoSet_A)
XXXXXXXXXX (missing command in order to define set_0, i.e. define set_B then (topoSet_A-set_B) )
refineMesh
snappyHexMesh -dict system/snappyHexMesh.2 (dictionary with only snap and layers enabled)
surfaceFeatureExtract and sHM substantially work in a virtual towing tank with stl file for the hull
Thank you in advance
gianlu.it is offline   Reply With Quote
meshing, refinement level, set
[snappyHexMesh] No satisfying result with feature edge refinement Krapf OpenFOAM Meshing & Mesh Conversion 5 December 13, 2019 06:59
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] sMH refinement level subhkirti OpenFOAM Meshing & Mesh Conversion 0 October 13, 2010 04:10
[snappyHexMesh] snappyHexMesh - Refinement Level andrea.pasquali OpenFOAM Meshing & Mesh Conversion 5 February 8, 2010 03:08
