[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. |
April 29, 2016, 06:22 |
Rep Power: 10 |
I have been trying to run some tutorials with snappyHexMesh but they all crash when snappyHexMesh gets executed.
For example in rotorDisk running ./Allrun i get Code:
Running blockMesh on /home/jasv/OpenFoam/tutorials/rotorDisk Running surfaceFeatureExtract on /home/jasv/OpenFoam/tutorials/rotorDisk Running snappyHexMesh on /home/jasv/OpenFoam/tutorials/rotorDisk /usr/.../openfoam/3.0.1/intel-openmpi/OpenFOAM-3.0.1/bin/tools/RunFunctions: line 42: 5886 Floating point exception(core dumped) $APP_RUN "$@" > log.$APP_NAME 2>&1 Running createPatch on /home/jasv/OpenFoam/tutorials/rotorDisk Running simpleFoam on /home/jasv/OpenFoam/tutorials/rotorDisk Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 ? at triangleFuncs.C:? #4 Foam::triangleFuncs::intersectBb(Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::treeBoundBox const&) at ??:? #5 Foam::treeDataPrimitivePatch<Foam::triSurface>::overlaps(int, Foam::treeBoundBox const&) const at ??:? #6 ? at triSurfaceSearch.C:? #7 ? at triSurfaceSearch.C:? #8 ? at triSurfaceSearch.C:? #9 ? at triSurfaceSearch.C:? #10 ? at triSurfaceSearch.C:? #11 ? at refinementSurfaces.C:? #12 ? at ??:? #13 __libc_start_main in "/lib64/libc.so.6" #14 ? at ??:? zsh: floating point exception (core dumped) snappyHexMesh -overwrite This error is in the main FAQ. I ran Code:
export WM_COMPILE_OPTION=Debug What should I do to get snappyHexMesh to work? |
May 1, 2016, 16:19 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick questions:
May 6, 2016, 03:44 |
Rep Power: 10 |
May 9, 2016, 08:10 |
Yasir Shkara
Hello Jasv,
I have the same problem when I run snappyHexMesh for any case, I'm using OF 3.01 did you get to any solution to this problem so far? Thanks! |
May 10, 2016, 02:55 |
Rep Power: 10 |
Not really, but I expect it to be a compiler error. On my debian with gcc 4.9, openmpi and default compilation settings it works well. In the wiki you can find a compatibility matrix.
floating point exception, snappyhexmesh |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
[snappyHexMesh] SnappyHexMesh crash (floating point exception while snappying) | Frank_uk | OpenFOAM Meshing & Mesh Conversion | 1 | January 9, 2016 06:19 |
Floating point exception in tutorials case | xujr | OpenFOAM Running, Solving & CFD | 0 | May 21, 2015 03:31 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 16:23 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 03:24 |
