[mesh manipulation] Questions about createPatch |
May 12, 2016, 21:01 |
Wentao Zheng
Rep Power: 12 |
Hi foamers. I am simulating a fan case. The mesh is generated by autogrid5 and the mesh file is .msh type. While the mesh is only one passage of the fan, I use the createPatch to make the periodic face cyclic. The createPatchDict is shown below.
name cyclic-0 Patchinfo type cyclic Neighbor patch cyclic-1 Transformation type: rotational Rotation axis: (0 0 1) Rotation center: (0 0 0) Construct from patches Patch (periodic1) name cyclic-1 Patchinfo type cyclic Neighbor patch cyclic-0 Transformation type: rotational Rotation axis: (0 0 1) Rotation center: (0 0 0) Construct from patches Patch (periodic2) I am sure that the periodic patches is matching. But when I used the createPatch utility, I was warned that "face area does not match neighbour by xx% --possible face ordering problem. " Has someone met this problem? Thanks for anyone's help. |
May 13, 2016, 03:18 |
These links should be useful: 1. http://openfoamwiki.net/index.php/CreatePatch (Refer to point 2 that is commented) 2. http://www.cfd-online.com/Forums/ope...port-icem.html Cheers, Antimony |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
createPatch cyclic boundary condition | KateEisenhower | OpenFOAM Pre-Processing | 3 | September 4, 2018 14:30 |
There is a bug in createPatch? | feno102 | OpenFOAM Pre-Processing | 6 | November 1, 2017 02:24 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
[Salome] unv mesh corrupted after createPatch | maddalena | OpenFOAM Meshing & Mesh Conversion | 1 | February 18, 2010 07:43 |
