[Gmsh] Problem meshing with larger control volume |
June 15, 2016, 05:03 |
Hi everybody,
I'm new in CFD and i'm trying to set up a 2D simulation of a nasa crm profile, using gmsh and openfoam. My unstructured mesh is working well until the lenght of the control volume is smaller than 10 times the profile chord, then it became irregular on the profile corrupting the mesh quality. My target is to create a control volume between 25 and 50 times chord dimension. I attached the .geo file and a screenshot of my problem. Where could be the problem? I think my code is quiet simple and clear but maybe some option is required. Thank you Attachment 48297 Attachment 48298 Last edited by gex; June 15, 2016 at 11:52. |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 11:44 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method | technocrat.prakash | Main CFD Forum | 1 | April 24, 2010 19:24 |
Gambit Meshing volume problem | haamdy | FLUENT | 11 | August 10, 2007 08:39 |
