[Gmsh] Problem meshing with larger control volume
Old   June 15, 2016, 05:03
Default Problem meshing with larger control volume
gex
gex is on a distinguished road
Hi everybody,
I'm new in CFD and i'm trying to set up a 2D simulation of a nasa crm profile, using gmsh and openfoam. My unstructured mesh is working well until the lenght of the control volume is smaller than 10 times the profile chord, then it became irregular on the profile corrupting the mesh quality. My target is to create a control volume between 25 and 50 times chord dimension. I attached the .geo file and a screenshot of my problem.
Where could be the problem? I think my code is quiet simple and clear but maybe some option is required.
Thank you
Attachment 48297
Attachment 48298
gex is offline   Reply With Quote
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 11:44
Problem with an old Simulation FrankW CFX 3 February 8, 2016 04:28
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method technocrat.prakash Main CFD Forum 1 April 24, 2010 19:24
Gambit Meshing volume problem haamdy FLUENT 11 August 10, 2007 08:39
