[snappyHexMesh] sHM layer reduction towards outlet |
May 17, 2016, 05:50 |
Hugo
Hello Foamers,
I have a question regarding layer insertion in sHM: I have a surface in my model which should be layered (e.g. wall) and an adjacent surface that should have no layer (e.g. an outlet), its 3dimensional, look at the picture below (outlet is at the bottom) sHM is decreasing my layers towards the surface that has no layers - why? I already played with some parameters like nGrow or featureAngle, but with no success. Maybe some of you have a hint. cheers
Fährste quer, siehste mehr! |
May 19, 2016, 09:33 |
Hugo
no ideas?
May 19, 2016, 18:37 |
Rep Power: 24 |
Can you post your snappy dictionary? I'll bet it has to do with the angles in the prism layer setup.
May 20, 2016, 07:14 |
Hugo
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; meshQuality true; snap true; addLayers true; geometry { var1e_swx_from_icem_flaechen_benannt_cutted.stl { type triSurfaceMesh; name var1e_swx_from_icem_flaechen_benannt_cutted; regions { OUTLETS { name outlets;} ROHRE { name rohre;} INLET { name inlet;} QUERKANAL1 { name querkanal1;} QUERKANAL2 { name querkanal2;} QUERKANAL3 { name querkanal3;} KRUEMMER1 { name kruemmer1;} /*KRUEMMER2 { name kruemmer2;} KRUEMMER3 { name kruemmer3;} KRUEMMER4 { name kruemmer4;}*/ HEADER1 { name header1;} HEADER2 { name header2;} HEADER3 { name header3;} HEADER4 { name header4;} HEADER5 { name header5;} HEADER6 { name header6;} HEADER7 { name header7;} HEADER8 { name header8;} /*HEADER9 { name header9;} HEADER10 { name header10;} HEADER11 { name header11;} HEADER12 { name header12;}*/ SYMM { name symm;} } } feinebox { type searchableBox; min (3 8 0); max (26 8.3 6); } }; castellatedMeshControls { maxGlobalCells 40000000; maxLocalCells 1000000; minRefinementCells 0; nCellsBetweenLevels 3; features ( { file "var1e_swx_from_icem_flaechen_benannt_cutted.eMesh"; level 0; } ); refinementSurfaces { var1e_swx_from_icem_flaechen_benannt_cutted { level (2 3); regions { rohre { level (2 3); } outlets { level (2 3); } inlet { level (2 3); } querkanal1 { level (2 3); } querkanal2 { level (2 3); } querkanal3 { level (2 3); } kruemmer1 { level (2 3); } /*kruemmer2 { level (2 3); } kruemmer3 { level (2 3); } kruemmer4 { level (2 3); }*/ header1 { level (2 3); } header2 { level (2 3); } header3 { level (2 3); } header4 { level (2 3); } header5 { level (2 3); } header6 { level (2 3); } header7 { level (2 3); } header8 { level (2 3); } symm { level (2 3); } inlet { level (2 3); } outlets { level (2 3); } //header12 { level (2 3); } } } } refinementRegions { feinebox { mode inside; levels ((1E15 0)); } } resolveFeatureAngle 30; allowFreeStandingZoneFaces true; locationInMesh (5.0005000511194281582016 9.007272265124 1.00005000014285523886); maxLoadUnbalance 0.10; } addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Expansion factor for layer mesh // expansionRatio 1.1; //- Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // See relativeSizes parameter. thickness 0.2; firstLayerThickness 0.2; //- Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.000001; /* möglich sind: first layer thickness ('firstLayerThickness') and overall thickness ('thickness') or first layer thickness ('firstLayerThickness') and expansion ratio ('expansionRatio') or final layer thickness ('finalLayerThickness') and expansion ratio ('expansionRatio') or final layer thickness ('finalLayerThickness') and overall thickness ('thickness') or overall thickness ('thickness') and expansion ratio ('expansionRatio' */ layers { rohre { nSurfaceLayers 1; } querkanal1 { nSurfaceLayers 1; } querkanal2 { nSurfaceLayers 1; } querkanal3 { nSurfaceLayers 1; } kruemmer1 { nSurfaceLayers 1; } /*kruemmer2 { nSurfaceLayers 1; } kruemmer3 { nSurfaceLayers 1; } kruemmer4 { nSurfaceLayers 1; }*/ header1 { nSurfaceLayers 1; } header2 { nSurfaceLayers 1; } header3 { nSurfaceLayers 1; } header4 { nSurfaceLayers 1; } header5 { nSurfaceLayers 1; } header6 { nSurfaceLayers 1; } header7 { nSurfaceLayers 1; } header8 { nSurfaceLayers 1; } //symm { nSurfaceLayers 1; } //inlet { nSurfaceLayers 1; } outlets { nSurfaceLayers 0; } //header12 { nSurfaceLayers 1; } } //- If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // This specifies the number of layers of connected faces that are not grown. This helps in convergence of the layer addition process close to features. nGrow 0; // Advanced settings //- When not to extrude surface. 0 is flat surface, 90 is when two faces // make straight angle. featureAngle 210; //180; //130 SlipFeatureAngle 75; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 40; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 6;//3 // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 6;//3 // Smooth layer thickness over surface patches nSmoothThickness 30;//10 // Stop layer growth on highly warped cells // This specifies the maximum allowable value of aspect ratio. Sometimes (especially in corners) the layers must be generated over highly warped cells. The layer generation will stop for cells where aspect ratio is higher than this value. maxFaceThicknessRatio 50;//0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.8;//0.3 // Angle used to pick up medial axis points minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 2; //0 // Overall max number of layer addition iterations nLayerIter 50; // No of steps walking away from the surface (to stop dislocations walking through the mesh) nMedialAxisIter 1000; // default: 2^31 (unlimited) } snapControls { nSmoothPatch 5;//3 von 3 im vgl zu #1 tolerance 1.5; //vorher 1.5 nSolveIter 300; explicitFeatureSnap true; implicitFeatureSnap false; multiRegionFeatureSnap true; nRelaxIter 10; nFeatureSnapIter 10; } meshQualityControls { maxNonOrtho 65;//180; //50; // 65 maxBoundarySkewness 5;//-1;//20; von 20 im vgl zu #1 maxInternalSkewness 4;//-1;//4; von 0.5 im vgl zu #1 maxConcave 80;//180;//80; minVol 1e-13;//-1e-33;//1e-13; minTetQuality 1e-30;//-1e-30;//1e-30; minArea -1; minTwist 0.02;//-1e-30; //0.02; minDeterminant 0.001;//-1; //0.001; //0.001 minFaceWeight 0.02;//-1; //0.02; minVolRatio 0.01;//-1; //0.01; minTriangleTwist 0.01;//-1; nSmoothScale 4; errorReduction 0.75; //0.75; } debug 0; mergeTolerance 1e-2; // ************************************************************************* // Reuslting from this sHM dict: Picture #1 shows the transition of the BL from "rohre" to "symm" and pic #2 shows transition from "rohre" to "outlets". In both cases the BL should have been projected onto the face which should have no BL (i.e. symm and outlets respectively). In my sHM dict I tried to either comment out BL for symm or say "zero layers" for "outlets", both don't work. When you talk about the feature angle.. I also attached 2 pictures that show a parametric study of this angle starting at 90° at the left going to 180° to the right (for the first picture) and a detailed study from 150° t165° to 180°. You can see that none of the cases is satisfying, since the BL either won't go around the corner or is not projected on the left wall where I don't want to have a BL.
May 21, 2016, 03:51 |
Francesco Del Citto
Rep Power: 18 |
Hi Hugo,
I think the answer to your question is in the code. Have a look to src/mesh/autoMesh/autoHexMesh/autoHexMeshDriver/autoLayerDriver.C In the method Foam::autoLayerDriver::doLayers you can find: // Per patch the number of layers (-1 or 0 if no layer) const labelList& numLayers = layerParams.numLayers(); layerParams is an object containing what is read from sHMDict. The difference between -1 or 0 can be seen in // Construct pointVectorField with correct boundary conditions for adding // layers Foam::tmp<Foam:: pointVectorField> Foam::autoLayerDriver::makeLayerDisplacementField There, all the patches are set to slip: wordList patchFieldTypes ( pointPatches.size(), slipPointPatchVectorField::typeName ); Apart from the patches where numLayers is 0 or >0: forAll(numLayers, patchI) { // 0 layers: do not allow slip so fixedValue 0 // >0 layers: fixedValue which gets adapted if (numLayers[patchI] == 0) { patchFieldTypes[patchI] = zeroFixedValuePointPatchVectorField::typeName; } else if (numLayers[patchI] > 0) { patchFieldTypes[patchI] = fixedValuePointPatchVectorField::typeName; } } So, if you set nSurfaceLayers to -1 for the patches symm and outlets, they will be set to slip and the points should slide to accommodate the prisms grown on the adjacent patches. Hope it helps, Francesco |
May 23, 2016, 06:39 |
Hugo
Hello Francesco,
thank you for your suggestion, I set nSurfaceLayers -1 for symm, inlet and outlets as you wrote, but it does´t work Have you tried it? regards
May 24, 2016, 02:53 |
Hugo
pls find the download link of a minimum example: https://we.tl/kjyiZhC6ZX
May 25, 2016, 00:14 |
Francesco Del Citto
Rep Power: 18 |
No, I haven't tried it recently and I don't know when I can try it again. What I am sure is that I had prisms doing what you want on a patch coming from blockMesh. In this case the patch is defined as symmetryPlane in blockMeshDict and it is not specified at all in the snappyHexMeshDict.
I don't know how much this could help you. I'll let you know if I manage to try your test case. Francesco |
June 17, 2016, 03:42 |
Hugo
still andybody has no ideas?
[snappyHexMesh] SHM addLayers doesnt work on the small surface | handicraft | OpenFOAM Meshing & Mesh Conversion | 4 | October 5, 2018 03:50 |
[snappyHexMesh] Problem airfoil snappyhexmesh add layer | bye bye my blue | OpenFOAM Meshing & Mesh Conversion | 1 | May 5, 2017 05:56 |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 01:56 |
[snappyHexMesh] SHM is assigning all faces to the first patch? | me3840 | OpenFOAM Meshing & Mesh Conversion | 2 | September 20, 2015 20:03 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
