[snappyHexMesh] Snappy extruding my .stl file through my blockMesh
Old   May 23, 2016, 15:16
Default Snappy extruding my .stl file through my blockMesh
Abigail Stehno
abigail_s is on a distinguished road
I am trying to place a floating box (.stl file) into a larger box (blockMesh file) using snappyHexMesh.
The problem is that the floating box cuts through the entire blockMesh, creating a rectangular hole in the mesh rather than a floating box.
The dimensions of the blockMesh are x=0:8.5 , y=-1:1 , z= 0:0.9
and the dimensions of the floating box are x=4:5 , y=0:0.4 , z= 0.2:0.5
so the floating box should be within the confines of the original mesh
Thanks in advance for any suggestions and help!
abigail_s is offline   Reply With Quote
Old   May 24, 2016, 21:21
Abigail Stehno
I have solved my problem- I was working in a 2D mesh in the y direction!
mesh, openfoam 2.3.0, snappyhexmesh
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
