[snappyHexMesh] snappyHexMesh not adding layers to a solid |
June 3, 2016, 08:25 |
Max Vorstadt
Rep Power: 10 |
Hi! I have run snappyHexMesh with the layer addition activated at the snappyHexMeshDict but apparently the output at the log file indicates that any layer addition was made to one of the two stl files.
The final lines of the log file are these ones: Code:
Doing final balancing --------------------- Writing 3205648 added cells to cellSet addedCells Writing 2717073 faces inside added layer to faceSet layerFaces Writing fields with layer information: nSurfaceLayers : actual number of layers thickness : overall layer thickness thicknessFraction : overall layer thickness (fraction of desired thickness) patch faces layers overall thickness [m] [%] ----- ----- ------ --- --- Cylinder 85669 0 0 0 Plate_round 701455 4.57 0.0017 58 |
layers, mesh, snappyhexmesh, stl |
[snappyHexMesh] Adding Layers in edges | ch_jaehnel | OpenFOAM Meshing & Mesh Conversion | 0 | November 2, 2016 07:19 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
chtMultiRegionSimpleFoam | samiam1000 | OpenFOAM Running, Solving & CFD | 39 | March 31, 2016 08:43 |
chtMultiRegionSimpleFoam: strange error | samiam1000 | OpenFOAM Running, Solving & CFD | 26 | December 29, 2015 22:14 |
[snappyHexMesh] snappyHexMesh: problems with layers | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 17 | June 10, 2012 04:26 |
