[Commercial meshers] A problem to use the mesh made by ICEM in openfoam
Old   June 4, 2016, 12:17
Default A problem to use the mesh made by ICEM in openfoam
Hong
278379rea is on a distinguished road
I made a two-dimensional airfoil mesh by ICEM and saved it in .msh file format. But when I use the fluentMeshToFoam in openfoam(ubuntu), I have a problem and I cannot understand it. I offer the pictures of its running result.
278379rea is offline   Reply With Quote
Old   June 5, 2016, 14:36
Hrvoje Jasak
Export the mesh in ascii format and all will be well.
Hrv
Hrvoje Jasak
Old   June 6, 2016, 00:20
Hong
Hrv
Really thank you. But how can I export my mesh in ascii format? ICEM can have this function, right?
Old   June 6, 2016, 02:54
Hong
Hrv
I have solved the problem I had before. Really thank you for your advice!
But I have a new problem, the following is the terminal log:
| \\ / O peration | Version: 3.0.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 3.0.1-119cac7e8750
Exec : fluentMeshToFoam NACA0012.msh -scale 0.1
Date : Jun 06 2016
Time : 14:43:30
Host : "katorirea-pc"
PID : 3373
Case : /home/katorirea/OpenFOAM/katorirea-3.0.1/run/tutorials/incompressible/icoFoam/nacaair
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
fileName::stripInvalid() called for invalid fileName classimmerseBoundaryPolyPatch~
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
[Commercial meshers] Importing ICEM Multiregion Mesh In OpenFOAM Aditya Patil OpenFOAM Meshing & Mesh Conversion 1 May 8, 2017 21:33
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
[ANSYS Meshing] problem in HEX-tet mesh generation in ICEM himanshu28 ANSYS Meshing & Geometry 24 October 28, 2012 11:17
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
ICEM Tetra mesh, Size reduction and Skewness problem Catthan ANSYS Meshing & Geometry 6 December 5, 2010 19:39
