[Other] Cells with high-value of velocity
Old   June 10, 2016, 01:01
Default Cells with high-value of velocity
Svensen is on a distinguished road
Hi, I've computed a potentialFoam and got a strange result. In a few number of cells the velocity value is too high (>0.8 m/s). The normal velocity value ranges in [0; 0.5]. The screenshot is attached.
Maybe someone know the reason of this issue and how to fix it ?
Maybe I need to change some parameter in snappyHexMeshDict or change a fvScheme ?
The project file is here: https://yadi.sk/d/1PZZCoagsPbTL
Svensen is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Access to the velocity at boundary cells mathslw OpenFOAM 14 January 9, 2018 23:31
Unrealistic values in cells at edge (high pressure & velocity) - fvSchemes?! matzbanni OpenFOAM Running, Solving & CFD 8 August 24, 2015 16:46
Removing cells with high skewness Parag Gadgil FLUENT 0 July 11, 2011 01:52
Removing cells with high skewness Parag Gadgil Main CFD Forum 0 July 9, 2011 03:46
