November 23, 2019, 11:01 |
Number of cells
Sama
Rep Power: 7 |
How I can define number of cells in my blockmeshDict: blocks ( hex (0 9 8 1 10 19 18 11) (16 16 216) simpleGrading (1 1 1) hex (1 8 5 2 11 18 15 12) (16 16 216) simpleGrading (1 1 1) hex (2 5 4 3 12 15 14 13) (16 16 216) simpleGrading (1 1 1) hex (8 7 6 5 18 17 16 15) (16 16 216) simpleGrading (1 1 1) ); I dont know how (16 16 216) is defined?? AS I want to use this code for other geometry and dont know where I should find number of cells in x, y and Z direction. Thank you, |
November 24, 2019, 06:50 |
Carlo_P
Rep Power: 7 |
Hey,
you can have a look into: http://www.wolfdynamics.com/wiki/mes..._blockmesh.pdf In this case: blocks ( hex (0 9 8 1 10 19 18 11) (16 16 216) simpleGrading (1 1 1) hex (1 8 5 2 11 18 15 12) (16 16 216) simpleGrading (1 1 1) hex (2 5 4 3 12 15 14 13) (16 16 216) simpleGrading (1 1 1) hex (8 7 6 5 18 17 16 15) (16 16 216) simpleGrading (1 1 1) ); 16 16 216 are the number of cells respectively in x,y,z direction. The (1 1 1) is the value of grading, if you want to have an homogeneous division. If you are an user, use always (1 1 1). Another trick: try to use the same dimension (number of cells/extension of the box) in every direction, in order to start with an homogenus mesh. |
November 24, 2019, 10:49 |
reply
Sama
Rep Power: 7 |
Hello Carlo,
Thank you so much for your answer. If I change the number of cells to (16 16 16), does it make any problem for my results accuracy? because my geometry dimension is not the same in XY and Z direction. Thnak you, |
November 24, 2019, 11:49 |
Carlo_P
Rep Power: 7 |
Yes, if you change in (16 16 16) you should have a coarser mesh, so, probably a less accurate result.
Furthermore, you can also have stability problem, due to the small quality of the mesh, since the blockMesh cells are very not regular. You have to set the (xcell ycell zcell) in order to have a quite regular hexaedral, so the xcell should be xlength/cellDimension ycell should be ylength/cellDimension zcell should be zlength/cellDimension where cellDimension should the same. Obviously, this is a very simple first rule. |
November 26, 2019, 09:05 |
Inconsistent number of faces
Sama
Rep Power: 7 |
Hello Carlo,
Thank you so much for your reply. I dont know what is wrong with my mesh. I get error of "Inconsistent number of faces between block pair 0 and 1". Here is copy of my blockmesh dict: FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 1; vertices ( (-296 -296.6 -5000) (-296 -296.6 2192) (-296 -296.6 2792) (-296 -296.6 2992) (-296 296.6 2992) (-296 296.6 2792) (-296 396.6 2792) (-296 396.6 2192) (-296 296.6 2192) (-296 296.6 -5000) (296 -296.6 -5000) (296 -296.6 2192) (296 -296.6 2792) (296 -296.6 2992) (296 296.6 2992) (296 296.6 2792) (296 396.6 2792) (296 396.6 2192) (296 296.6 2192) (296 296.6 -5000) ); blocks ( hex (0 9 8 1 10 19 18 11) (16 16 194) simpleGrading (1 1 1) hex (1 8 5 2 11 18 15 12) (16 16 22) simpleGrading (1 1 1) hex (2 5 4 3 12 15 14 13) (16 16 5) simpleGrading (1 1 1) hex (8 7 6 5 18 17 16 15) (16 2 22) simpleGrading (1 1 1) ); edges ( ); boundary ( frontAndBack { type wall; faces ( (10 11 18 19) (11 12 15 18) (12 13 14 15) (18 15 16 17) (9 8 1 0) (8 5 2 1) (5 4 3 2) (7 6 5 8) ); } walls { type wall; faces ( (0 1 11 10) (1 2 12 11) (2 3 13 12) (15 14 4 5) (16 15 5 6) (18 17 7 8) (19 18 8 9) ); } outlet { type patch; faces ( (0 10 19 9) ); } inletone { type patch; faces ( (3 13 14 4) ); } inlettwo { type patch; faces ( (17 16 6 7) ); } ); Could you please help me how to solve this problem? Thanks alot! |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
