[blockMesh] How to define symmetric graded mesh without using multiple blocks
Old   June 24, 2016, 13:30
Default How to define symmetric graded mesh without using multiple blocks
Sheikh Ahmed
sahmed is on a distinguished road
Dear Foamers
I am a confused about a very basic question, which you can give me some suggestion from your experience. I am using blockMesh and if I want to have a symmetric kind of graded mesh, like finer at the entry and exit of the block (can be symmetric) and coarser in the middle, how can I do this with a single block without defining multiple blocks?
I hope I could explain my question correctly to you. It might be very easy, but not clicking me right now.
PLEASE help me if anyone did this before.
sahmed is offline   Reply With Quote
Old   June 24, 2016, 14:57
Default blockMeshDoubleGrading
Sheikh Ahmed
Does the blockMeshDoubleGrading utility serve this purpose and is it compatible with OF version 2.3.1?? It can just double the mesh size in the middle, cant make 3 times or 4 times, right?
Also can anyone tell me the steps to add this in openFOAM?
Old   June 27, 2016, 10:54
Sheikh Ahmed
Anyone has any idea to help me?
Old   August 18, 2016, 03:33
Dan
Danubi is on a distinguished road
Hi Sahmed,
I'm facing similar case these days. Have you checked this?:
http://cfd.direct/openfoam/user-guide/blockmesh/
Chapter 5.3.1.4 Multi-grading of a block.
I think you can save lots of time with it.
Regards
Danubi is offline   Reply With Quote
blockmesh, graded mesh, symmetric mesh
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[Other] Multiple blocks for moving mesh jiahui_93 OpenFOAM Meshing & Mesh Conversion 0 March 4, 2018 02:24
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
