[mesh manipulation] Tutorial AMI for beginner
Like Tree7Likes
  • 7 Post By Tobi
Old   November 10, 2015, 15:43
Default Tutorial AMI for beginner
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
today I added a new tutorial that is using sHM to create a AMI for a spiral conveyor (just very simple). Of course there are other ways to make the AMI interface (setSet and createPatch -> baffles) but here it is:
https://holzmann-cfd.de/
phsieh2005, cutter, fumiya and 4 others like this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   June 30, 2016, 09:05
alex
crusen mind is on a distinguished road
hello holzmann
when I run spiral conveyor I am getting this error
- Update AMI patch infos / also changeDict could be used
./run: line 48: createPatch: command not found
End Meshing
Start moving the mesh (could take a while)
- Run application moveDynamicMesh
./run: line 67: moveDynamicMesh: command not found
End of moving
crusen mind is offline   Reply With Quote
Old   June 30, 2016, 09:54
Tobi's Avatar
Tobias Holzmann
Dear Alex,
as you can see from the messages there is a problem in your FOAM installation. createPatch is a foam application. If you load your foam variables and type createPatch you should get some output. You can check it like that:
source $HOME/.bashrc
which icoFoam
which createPatch
If there is no output for the last command, then your FOAM installation is not correct.
Keep foaming,
Tobias Holzmann
Old   July 29, 2016, 00:02
alex
hi tobi
I am trying to run propeller simulation using PimpleDyM foam. my solution is not converging. please tell me if something is wrong. I will post my checkMesh, controlDict, Fv soltuion,files.
checkMesh File
PHP Code:
Build  4.0-665f1db4c1f1
Exec
checkMesh
Date
Jul 28 2016
Time
11:36:29
Host
"velan-OptiPlex-9020"
PID    3301
Case   : /home/velan/prop
nProcs
1
sigFpe
Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking Monitoring run-time modified files using timeStampMaster
allowSystemOperations
Allowing user-supplied system call operations
Create time
Create polyMesh
for time 0
Time
0
Mesh stats
    points
:           43715
    faces
:            463930
    internal faces
:   437866
    cells
:            225449
    faces per cell
:   4
    boundary patches
5
    point zones
:      0
    face zones
:       0
    cell zones
:       2
Overall number of cells of each type
hexahedra:     0
    prisms
:        0
    wedges
:        0
    pyramids
:      0
    tet wedges
:    0
    tetrahedra
:    225449
    polyhedra
:     0
Checking topology
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions2
    The mesh has multiple regions which are not connected by any face
Writing region information to "0/cellToRegion"
<<Writing region 0 with 94543 cells to cellSet region0
<<Writing region 1 with 130906 cells to cellSet region1
Checking patch topology
for multiply connected surfaces...
Patch               Faces    Points   Surface topology
    default_exterior    4376     2192     ok
(closed singly connected)
propeller           6596     3298     ok (closed singly connected)
wall                11740    5964     ok (non-closed singly connected)
outlet              1672     884      ok (non-closed singly connected)
inlet               1680     888      ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.3 -0.5 -0.3) (0.3 0.55 0.299999)
Mesh has 3 geometric (non-empty/wedgedirections (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (1.79007e-16 1.7051e-16 1.35631e-15OK.
Max cell openness 3.87662e-16 OK.
Max aspect ratio 10.1853 OK.
Minimum face area 6.27344e-08Maximum face area 0.000731502.  Face area magnitudes OK.
Min volume 1.54049e-11Max volume 6.02718e-06.  Total volume 0.296711.  Cell volumes OK.
Mesh non-orthogonality Max60.8432 average18.7601
    Non
-orthogonality check OK.
Face pyramids OK.
Max skewness 1.11566 OK.
Coupled point location match (average 0OK.
Mesh OK.
End
control dict file
PHP Code:
/application     pimpleDyMFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.1;
deltaT          0.000001;
writeControl    adjustableRunTime;
writeInterval   0.001;
////- For testing with moveDynamicMesh
//deltaT          0.01;
//writeControl    timeStep;
//writeInterval   1;
purgeWrite      0;
writeFormat     binary;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           2;
functions
#includeFunc Q
    #include "surfaces"
    #include "forces"
my Fv solution file
PHP Code:
solvers
pcorr
solver          GAMG;
tolerance       1e-2;
relTol          0;
smoother        DICGaussSeidel;
cacheAgglomeration no;
maxIter         50;
p
$pcorr;
tolerance       1e-5;
relTol          0.01;
pFinal
$p;
tolerance       1e-6;
relTol          0;
"(U|k|epsilon)"
solver          smoothSolver;
smoother        symGaussSeidel;
tolerance       1e-6;
relTol          0.1;
"(U|k|epsilon)Final"
tolerance       1e-6;
relTol          0;
PIMPLE
correctPhi          no;
nOuterCorrectors    2;
nCorrectors         1;
nNonOrthogonalCorrectors 1;
relaxationFactors
"(U|k|epsilon).*"   1;
cache
grad(U);
Old   September 12, 2016, 12:18
Damian
Cooltyvator is on a distinguished road
Can someone upload this tutorial? Link is unavailable.
Cooltyvator is offline   Reply With Quote
Old   September 12, 2016, 12:28
Tobi's Avatar
Tobias Holzmann
Thanks for the note. I repaired the link (need a while after it will be available). Finally, you could solve the problem yourself if you took one minute to check out my site. Well here is the link: https://Holzmann-cfd.de
Maybe the new one is also of interest: http://www.cfd-online.com/Forums/ope...-tutorial.html
Keep foaming,
Tobias Holzmann
Old   July 15, 2017, 05:07
parth chavan
pthcvn1990 is on a distinguished road
Originally Posted by Tobi View Post
Hi all,
holzmann,
On clicking the new tutorial link, it is directing me to your login page. There is no option for registration.
May I know how to register for your website?
regards.
pthcvn1990 is offline   Reply With Quote
Old   July 15, 2017, 05:17
Tobi's Avatar
Tobias Holzmann
I am sorry that you cannot access to my website right now because I am working on it. However, questions like yours make me sad because it demonstrates that people don't read anything :/. If you just read the two sentence that I provide you would know what is going on:
Dear fellows, cfd enthusiasts and FOAM'er. I am working on my page. --> Numerical Schemes are going to be extended with a polygon mesh and all data are recalculated and automatized (scripts will be included that everybody can use it for the research). Kind regards, Tobias Holzmann
I am sorry that no one has actually access to it. I am working on it. Today in the evening my site should be available again.
Kind regards,
Tobias Holzmann
Keep foaming,
Tobias Holzmann
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
mapField error rvl565 OpenFOAM Pre-Processing 1 September 6, 2018 16:13
ICEM and AMI unfinished tutorial sharonyue OpenFOAM Running, Solving & CFD 11 September 24, 2014 10:15
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Trouble with simple AMI case Horus OpenFOAM 0 February 26, 2013 09:31
