[snappyHexMesh] Snappy does not snap to curved surfaces |
September 25, 2016, 10:18 |
Annika Blom
Rep Power: 10 |
I've been working to solve this problem for some days now, but I can't get a solution. Also the posts in forums and google search do not help. I try to mesh a channel with a concave surface (see attached pictures). It seems like snappyHexMesh is doing the first snapping step, but not the snapping to the surface. I already tried to increase the number of cells in my background mesh and the refinement level. Also I tried to increase and decrease the number of maximum local and global number of cells but nothing helps. SnappyHexMesh meshes the same channel with a non concave surface (a rectangular channel) with the same meshing options quite well. Do you have any suggestions or ideas where my mistake is? Thanks in advance for any input! Akinna STL_ConcaveSurface.jpg Mesh_ConcaveSurface.jpg blockMeshDict.txt snappyHexMeshDict.txt |
September 26, 2016, 06:52 |
Update
Annika Blom
Rep Power: 10 |
Hey,
I tried to mesh only half of the channel with the same mesh settings and here snappyHexMesh is snapping quite well (see Image below). Mesh_HalfDomain.jpg Half of the channel means, that the Geometry is 16m long and 0.14m wide (the whole channel is 32m long). Any ideas what is going wrong while meshing the long channel? Greetings Akinna |
September 26, 2016, 15:18 |
Hello Akinna,
I have no idea why you obtain these results from sHM, but if you can share your stl or obj file, I'd like to investigate this with you. I'll be doing something with long channels in the near future, and hence may run into the same problem as you have... cheers, Laika, still orbiting |
September 29, 2016, 06:48 |
Annika Blom
Rep Power: 10 |
Hey Laika,
I am sorry for the late reply, but I am not allowed to share the STL-Files. I am still working to solve the problem. Gonna let you know when I find a solution. Cheers Akinna |
September 30, 2016, 05:57 |
Annika Blom
Rep Power: 10 |
Hey,
I found a solution here: http://www.cfd-online.com/Forums/ope...pped-mesh.html I turned down the nsolveIter to 30 and now the mesh looks quite good. Cheers Akinna |
September 30, 2016, 08:14 |
#6 | |
Anonymouse
Rep Power: 10 |
October 4, 2016, 06:27 |
Annika Blom
Rep Power: 10 |
Hey KarenRei,
thanks for your answer. Yes this was also my first thought but increasing the max number of cells didn't help. Cheers Annika |
Sampling curved surfaces | sega | OpenFOAM Post-Processing | 0 | July 12, 2009 11:40 |
curved surfaces in airpak | francesco montagnani | FLUENT | 2 | April 3, 2004 03:08 |
Normal Vector on Curved Surfaces | Karl | FLUENT | 0 | July 2, 2001 04:35 |
Law of the wall on curved surfaces | Rasputin | Main CFD Forum | 3 | November 2, 1998 09:28 |
