[blockMesh] error in using #codeStream for making blockMeshDict
Old   October 9, 2016, 18:12
Default error in using #codeStream for making blockMeshDict
Bobby
babakflame is on a distinguished road
Dear Fellows
I am trying to use #codeStream in blockMeshDict file to create a simple grid. The following is my blockMeshDict file initial lines:
convertToMeters 1;
vertices  #codeStream
    codeInclude
        #include "pointField.H"
    code
        pointField points(8);
        points[0] = point(0 0 0);
        points[1] = point(2 0 0);
        points[2] = point(2 0.05 0);
        points[3] = point(0 0.05 0);
        points[4] = point(0 0 0.05);
        points[5] = point(2 0 0.05);
        points[6] = point(2 0.05 0.05);
        points[7] = point(0 0.05 0.05);
        os << points;
blocks
    hex (0 1 2 3 4 5 6 7) (280 7 1) simpleGrading (1 1 1)
During compilation of grid, it returns the following error:
home/babak/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/Vector.H:58:7: note:   no known conversion for argument 1 from ‘int’ to ‘const Foam::Vector<double>&’
/home/babak/Desktop/second_version_simulations/Coarse_Grid/X_10/j0_1/constant/polyMesh/blockMeshDict::#codeStream:34:20: error: expected primary-expression before ‘(’ token
/home/babak/Desktop/second_version_simulations/Coarse_Grid/X_10/j0_1/constant/polyMesh/blockMeshDict::#codeStream:34:23: error: expected ‘)’ before numeric constant
make: *** [Make/linux64GccDPOpt/codeStreamTemplate.o] Error 1
Would some one please hint me where did I make mistake in writing #codeStream??
The full blockMeshDict file is attached as well.
The above grid compiles with removing code stream and defining vertices normally
Regards
babakflame is offline   Reply With Quote
Old   October 9, 2016, 18:24
Bobby
Oh Gosh. Problem Solved.
points Should be defined like this:
code
        points[0] = point(0, 0,       0);
        points[1] = point(2, 0,       0);
        points[2] = point(2, 0.05,    0);
        points[3] = point(0, 0.05,    0);
        points[4] = point(0, 0,    0.05);
        points[5] = point(2, 0,    0.05);
        points[6] = point(2, 0.05, 0.05);
        points[7] = point(0, 0.05, 0.05);
        os << points;
I had missed commas inside the parenthesis.
[blockMesh] #codeStream loop inside a blockMeshDict francois OpenFOAM Meshing & Mesh Conversion 31 March 13, 2021 12:29
[blockMesh] Creating an axisymmetric piston cylinder in blockMeshDict foadsf OpenFOAM Meshing & Mesh Conversion 9 August 23, 2018 07:54
How to create the internalField with #codeStream chun OpenFOAM Running, Solving & CFD 3 May 6, 2017 10:35
[blockMesh] 2:1 refined 2D blockMeshDict with mergePatchPairs? chrisb2244 OpenFOAM Meshing & Mesh Conversion 0 December 1, 2014 23:52
[Other] blockMeshDict not Matching Boundary HassanDarian OpenFOAM Meshing & Mesh Conversion 0 March 19, 2014 13:30
