[blockMesh] Create time fileName::stripInvalid() called for invalid fileName UbuntuOne For d
Old   September 17, 2013, 09:08
Default Create time fileName::stripInvalid() called for invalid fileName UbuntuOne For d
Tobi Morak
tobimorak is on a distinguished road
I got this error mesh after typing blockMesh, Can anyone help on how to solve this? I am a new user ..please help . here is d error message
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.1-57f3c3617a2d
Exec : blockMesh
Date : Sep 17 2013
Time : 21:00:42
Host : "tobie-Vostro-2521"
PID : 2402
Case : /home/tobie
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
tobimorak is offline   Reply With Quote
Old   September 26, 2013, 17:45
Wouter van der Meer
wouter is on a distinguished road
helo tobimorak,
You probably figured it out already. Openfoam does not like certain filenames in the case directory. In this case probably 'Ubuntu One' with a space.
Hope this helps
Wouter
wouter is offline   Reply With Quote
Old   September 26, 2013, 19:36
Tobi Morak
Thank You...I will try again
Old   October 4, 2016, 04:39
gned
gned is on a distinguished road
dear wouter,
I'm quite out of space in my ssd disk of my laptop by now. So I would often have the need to try/run/visualize some cases on an external USB I have, but which unfortunately is recognized as TOSHIBA EXT by the system, with a whitespace in the name! Is this possible modifying some files as fileName.H to make OF digest these names strings?
gned is offline   Reply With Quote
Old   October 4, 2016, 13:57
Wouter van der Meer
hello gned,
if you use linux you can make a link and use that in your filename. I have to find out myself how to do that, but google can tell you.
Hope that helps
Wouter
Old   October 4, 2016, 14:07
Wouter van der Meer
hello gned,
Thinking a little longer give me two other solutions. 1) start from the USB stick, no problem if the casedirectory has a space, only a problem if there are filenames in the casedirectory with spaces.
2) move a or some case directory(ies) from your ssd to a USB and than copy your new case to the ssd and start from the case directory
hope this helps
Wouter
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 09:03
