November 24, 2016, 15:14 |
Simplegrading does not work
Emre
Rep Power: 10 |
Hello everyone,
I have problem which has multiple regions and they are all blocks. blocks ( hex (0 1 2 3 4 5 6 7) (48 35 1) simpleGrading (0.90909 1.1 1) hex (8 9 10 11 12 13 14 15) (1000 35 1) simpleGrading (1 1.1 1) hex (16 17 18 19 20 21 22 23) (55 35 1) simpleGrading (1.1 1.1 1) hex (24 25 26 27 28 29 30 31) (48 1000 1) simpleGrading (0.90909 1 1) hex (32 33 34 35 36 37 38 39) (1000 1000 1) simpleGrading (1 1 1) hex (40 41 42 43 44 45 46 47) (55 1000 1) simpleGrading (1.1 1 1) hex (48 49 50 51 52 53 54 55) (48 35 1) simpleGrading (0.90909 0.90909 1) hex (56 57 58 59 60 61 62 63) (1000 35 1) simpleGrading (1 0.90909 1) hex (64 65 66 67 68 69 70 71) (55 35 1) simpleGrading (1.1 0.90909 1) simpleGrading does not seem exist as I want it. In order to give reverse bias, I stated my bias factor in -X axis as 0.90909 which means mesh cells are tightening. How is it possible? |
November 27, 2016, 11:10 |
Emre
Rep Power: 10 |
I tried same problem with different blocks order. Still same issue exists. Mesh grading does not work. It must be a bug or something. What is it wrong? Any idea?
bias, bias factor, blockmesh, blockmeshdict, simplegrading |
This mesh contains patches of type empty but is not 1D or 2D | oric | OpenFOAM Running, Solving & CFD | 36 | November 28, 2016 07:12 |
setfields for alpha | belkadi | OpenFOAM Programming & Development | 7 | November 25, 2014 11:53 |
[blockMesh] blockMesh fatal error, the default patch already has faces in it | samid | OpenFOAM Meshing & Mesh Conversion | 2 | February 17, 2014 13:35 |
[Other] mergeMatchPairs with arcs | vainilreb | OpenFOAM Meshing & Mesh Conversion | 1 | August 5, 2013 08:11 |
[blockMesh] tutorial 2.2 Stress(...) trouble with blockMesh | colinB | OpenFOAM Meshing & Mesh Conversion | 8 | January 22, 2012 10:32 |
