[mesh manipulation] Mesh refinement based on previous results |
December 27, 2016, 14:37 |
Rep Power: 10 |
Hi
is there a way to refine a mesh from the results (like velocity or pressure gradient) obtained from a past simulation? (I'm not looking for AMR) Thanks! |
May 4, 2017, 19:09 |
Thomas Oliveira
Rep Power: 12 |
I am looking for a way to do that too. My best guess up to the moment is that we should create one or more cellSets based on the values of a field, and then refine these cellSets using refineMesh or refineHexMesh. See this thread and this thread. I would be happy if someone could point out a more straightforward solution. Best wishes, Thomas |
July 3, 2017, 04:27 |
#3 | |
JD
Rep Power: 9 |
gradient, mesh, refine mesh |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] Bad/jagged mesh around intersection of two .stl bodies | MBttR | OpenFOAM Meshing & Mesh Conversion | 7 | October 14, 2016 03:57 |
[snappyHexMesh] sHM refinement away from surface | nholt | OpenFOAM Meshing & Mesh Conversion | 1 | June 14, 2016 14:36 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Mesh Refinement | JY | Siemens | 7 | September 19, 2002 13:37 |
