December 14, 2016, 09:04 |
Problems with snappyHexMesh
Sophie Balemans
Hi all!
I am trying to perform a MRF simulation of a hyperboloid impeller rotating at 26 rpm in a closed compartment . However, I am facing problems with meshing the corners of the blades of the hyperboloid impeller (see attached figure). The geometry of the impeller is created in Siemens NX, and exported as a .stl file. SnappyHexMesh was used to build the mesh. I uploaded the blockmesh and snappyHexMesh file here: https://www.dropbox.com/sh/ro2u2rh0c...iVAbXskea?dl=0 Any idea what to change in the settings of the snappyHexMesh file? Best Regards, Sophie Last edited by Sbaleman; December 14, 2016 at 11:07. Reason: forgot the link |
January 9, 2017, 04:46 |
Sophie Balemans
Dear all,
I am still have problems with meshing the impeller. I tried to change different settings in the surfaceFeatureExtract and snappyHexMesh files without any success. Does anyone know how I solve this problem? Thanks, Sophie |
January 9, 2017, 15:12 |
Daniel P. Combest
An easy way to improve this, is to
Most issues with snappyHexMesh are solved by increasing the resolution. |
January 9, 2017, 16:15 |
Suffolk
Rep Power: 10 |
Increase the min max level of surface refinement on them surfaces. What are your current settings?
Sent from my iPhone using CFD Online Forum mobile app |
impeller, multi reference frame, snappyhexmesh |
[snappyHexMesh] Problems with coarse/unsnapped cells in snappyHexMesh | scareneb | OpenFOAM Meshing & Mesh Conversion | 2 | August 13, 2014 07:13 |
[snappyHexMesh] snappyHexMesh problems 1.5->1.6 | grtabor | OpenFOAM Meshing & Mesh Conversion | 5 | May 18, 2012 03:00 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
[snappyHexMesh] SnappyhexMesh and Symmetryplane | bastil | OpenFOAM Meshing & Mesh Conversion | 10 | October 7, 2008 17:07 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 07:08 |
